Home > Puma (Tdci) > Puma central locking poor range fix
Page 2 of 3 <123>
pom
Mad Cow wrote:
Used bullet connectors on mine.
I was told the reason Land Rovers (and Rovers) were like this is to stop people "capturing" the code remotely and cloning it. On the basis you might notice someone with a little black box lurking suspiciously right beside the drivers door Mr. Green
Mind you sort of misses the point of remote central locking
Whoever told you that is full of Censored . The mod is effecting the receiver not the transmitter.
Pom
Post #36889 24th Jul 2010 11:57am
Mote
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Santorini Black
Did it with a small choci block connector, took no time at all and now get a lovely 10-13 metre range (ran the new cable just up into roof lining). Perfect.
Thanks for the tip.
Post #168572 15th Sep 2012 4:33pm
Dora
I'm trying to do this on my 11 plate 110 XS puma but don't have the orange and grey wire. In approximately the same place I have a plain piece of braided wire with no plastic shielding which goes into the loom. Could it be that one?
I did post this on another thread but don't think anyone is still watching it!
Post #428162 2nd Jun 2015 8:46pm
Clive
No it's not that one, it's orange with a grey trace on the Td5's, maybe a different colour on later ones? The giveaway though is that it's a short length (about 4-5") coming from one of the connectors and going nowhere - with an open end, that's the one to extend.
Post #428174 2nd Jun 2015 9:09pm
Dora
In that case I don't have one, all wires are firmly in the loom... Sad
Post #428180 2nd Jun 2015 9:16pm
Clive
There must be one in there somewhere, it wouldn't work at all without it, it might be taped into the loom? you might need to unbind the loom wrapping a little bit from that end.
Post #428185 2nd Jun 2015 9:21pm
Dora
To be honest I don't think I'll bother, it works as it is, just thought I could gain a little distance as it won't open at all if I'm on the nearside, I have to get within about 6 feet of the off side. It's still better than using the key Rolling Eyes
Post #428191 2nd Jun 2015 9:26pm
Clive
Might be worth checking the battery in the key fob?
Something I only found out yesterday was that if the indicator flash on unlock stops working, that's a signal that the fob battery is failing.
Post #428196 2nd Jun 2015 9:36pm
Dora
Thanks, but that I did know, It's quite near the beginning of the quick start manual..as it happens I changed it quite recently so I don't think it's a battery problem..although I have had those batteries flat from new so I could try another one!
Post #428197 2nd Jun 2015 9:43pm
munch90
Sometimes a long operating range can be a dodgy thing , for example if your out of site of defender and push button by mistake or kids playing with your keys etc then your defender is sitting unlocked without you knowing it
shame that they dont relock after 30 secs if door isnt openned as the later rover cars do
but then it can be a good thing as it could allow you you to check its locked from inside your house !
Post #428203 2nd Jun 2015 9:55pm
Clive
One of the settings on the 10AS is for "relock" and can be set if you have a diagnostic tool, Nanocom etc.
The only problem with "relock" is that it ignores opening of doors, you have to turn the ignition on to stop it from re-locking, so if you unlock, open a door and put your keys down while you rummage around for what you unlocked it for, then shut the door - keys locked in car Evil or Very Mad
Don't ask me how I know Embarassed
Post #428209 2nd Jun 2015 10:08pm
chiversn
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
Sorted mine in 15mins the other night.
Chock block and a spare bit of insulated wire (in the "that'll be handy one day" section of the garage).
Mine is now about 15m range.
Interesting point about accidental unlocking while walking away. I installed the extension up behind the B pillar cover, but I guess you could play with the range by only taking the extension up to dash height - in reality 5 metres would be plenty and still 10x what I had before! ----------------------------------------------------------------------------------------------
My first job involved driving from Southampton to Wick in a 300TDI (twice)
The experience of 3000 miles in a Defender has never left me (for many reasons!)
Post #428290 3rd Jun 2015 10:08am
24heuer
Scotland 2010 Defender 110 Puma 2.4 CSW Keswick Green
Same here - I was all set to give up and then I found this
http://defender90xs.blogspot.com/2014/11/r...nsion.html
My 2010 Puma has the same setup - white wire hanging loose behind the clock.
I found it by accident while refitting the stereo and thought I'd disconnected something - everything still worked so I just forgot about it Embarassed
I've extended it up the A-pillar anyway but the range is still very 'iffy'.
If I'm parked same place in the drive, sometimes it works from 30ft away and other times (ok, most of the time) I'm practically standing at the door before it'll work Confused Cheers,
Andy...
Edinburgh, Scotland
http://24heuer.com
Post #723526 15th Aug 2018 7:18am
neon1991
United Kingdom 2014 Defender 110 Puma 2.4 USW Firenze Red
110SEB wrote:
Try pressing the key fob against your temple and you will get up to 15m range all of a sudden!
I get at least 10mtrs by doing this Smile wifi routers also mess it up. I can blip the landy from the front of the house next to the router and nothing happens. I walk into the back garden and blip it, and it works...
Post #723595 15th Aug 2018 3:35pm
chiversn wrote:
... I installed the extension up behind the B pillar cover...
That's one hell of an extension! Rolling with laughter
Post #723597 15th Aug 2018 4:12pm
Page 2 of 3 <123>
