Home > Puma (Tdci) > Surging Drive and Clattering Noise
schuee
We are away down in Devon at the moment and the last few days I have experienced surging whilst at low speed and also noticed mainly going up hills, the engine sounds very clattery with black smoke could it be EGR related? I have contacted my dealer to make them aware, as my warranty runs out next month, if it gets any worse I suppose I could ring LR assist, any ideas gentlemen.
Keith
Post #352578 19th Aug 2014 6:35pm
rick
Australia 2008 Defender 110 Puma 2.4 SW Stornoway Grey
Sounds like the EGR valve is stuck open. 1998 RR HSE
2007 RRS TDV6
2008 Defender 110
2015 Discovery Sport
Post #352831 21st Aug 2014 7:13am
EGR, or possibly a common rail pressure issue, perhaps VCV or pressure limiting valve.
The fault should be apparent from stored DTCs. If there are no DTCs, I'd suspect the VCV.
Post #352840 21st Aug 2014 8:16am
schuee
Was still doing it last night from being parked up all day, then a few miles up the road driving ok, this morning clanking away and surging, still getting the chukka chukka after switch off, funny enough its been in before for running rough dealer said it may be possible vcv, though found no errors. Anyway its booked in next week and seems to be constant so should be easy to diagnose now. Could I disconnect the EGR ?
Keith
Post #352933 21st Aug 2014 3:54pm
schuee
Keith
Post #352935 21st Aug 2014 3:57pm
It is rare to get DTCs from a faulty VCV. Usually it is the presence of symptoms in the absence of any DTCs that indicates the VCV is malfunctioning. I'd fit a new one.
Post #352956 21st Aug 2014 5:56pm
schuee
Update
Defender has been at the dealers for first MOT and to resolve this problem, on investigation no DTC's logged and all running as it should though making clattering noise from cold, so ECU software upgraded and injector learn ran, and seems to be running fine now, anyway I'm happy again Smile
Post #355532 4th Sep 2014 8:49am
Caterham
poor connection / high resistance fault in the engine bay / harness?
Post #355554 4th Sep 2014 10:27am
schuee
Not sure if anything was checked like this,
Just a few quick questions though, I have had some warranty work carried out over the last 3 years, for example I had a new clutch fitted (3rd one Surprised ) earlier this year, now my warranty expires in a couple of weeks what length of warranty do LR give on parts fitted under warranty ? say if my clutch failed next month would LR honour replacement?
Also as a customer can I ask for a listed copy of all work / software updates carried out under warranty, basically for my records, and to pass on if I ever sold vehicle?
Post #355561 4th Sep 2014 11:26am
