![]() | Home > Puma (Tdci) > Surging Drive and Clattering Noise |
rick Member Since: 07 Mar 2008 Location: Perth Posts: 133 ![]() ![]() ![]() |
Sounds like the EGR valve is stuck open. 1998 RR HSE
2007 RRS TDV6 2008 Defender 110 2015 Discovery Sport |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17679 ![]() ![]() ![]() |
EGR, or possibly a common rail pressure issue, perhaps VCV or pressure limiting valve.
The fault should be apparent from stored DTCs. If there are no DTCs, I'd suspect the VCV. |
schuee Member Since: 16 Jul 2012 Location: Lincolnshire Posts: 378 ![]() ![]() ![]() |
Was still doing it last night from being parked up all day, then a few miles up the road driving ok, this morning clanking away and surging, still getting the chukka chukka after switch off, funny enough its been in before for running rough dealer said it may be possible vcv, though found no errors. Anyway its booked in next week and seems to be constant so should be easy to diagnose now. Could I disconnect the EGR ?
Cheers Keith |
Cheers Keith |
It is rare to get DTCs from a faulty VCV. Usually it is the presence of symptoms in the absence of any DTCs that indicates the VCV is malfunctioning. I'd fit a new one.
Defender has been at the dealers for first MOT and to resolve this problem, on investigation no DTC's logged and all running as it should though making clattering noise from cold, so ECU software upgraded and injector learn ran, and seems to be running fine now, anyway I'm happy again
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6324 ![]() ![]() ![]() |
poor connection / high resistance fault in the engine bay / harness?
Not sure if anything was checked like this,
Just a few quick questions though, I have had some warranty work carried out over the last 3 years, for example I had a new clutch fitted (3rd one ![]() Also as a customer can I ask for a listed copy of all work / software updates carried out under warranty, basically for my records, and to pass on if I ever sold vehicle? Cheers |
