Home > Puma (Tdci) > the clever wiring
Page 1 of 3 123>
Caterham
the clever wiring
So the canbus stuff
Are the various sensors etc on a loop or are they all wired individually on radial circuits?
Many thanks
Post #352042 16th Aug 2014 10:03pm
K9F
As an electrician who has experience with 1553 databus even I do not understand your question. A canbus can be a two way street to an individual or group of sensors or circuits so it sends signals and often expects something in return often on the same line. These return signals are differentiated from each other by seperate modulated frequencies or voltages that determine what sensor or circuit is responding and the information dealt with and processed accordingly.
It cannot be likened to a domestic installation with radial, spur or ring/loop like terminology. What is it exactly you are trying to achieve or wish to know? Try to be a little more specific.
If this is yet another of your fog knitting, wild goose chase theories please don't expect an answer anytime soon! Whistle If you go through life with your head in the sand....all people will see is an ar5e!!
Post #352043 16th Aug 2014 10:09pm
Roy5695
United Kingdom 2011 Defender 110 Puma 2.2 XS DCPU Indus Silver
ooooo, 1553 databus, lovely. combined with a bit of arinc 429 or 622 and you're on for a winner.
but yeah like k9f said, more info required.
Post #352047 16th Aug 2014 10:49pm
Caterham
Just trying to understanding whether items such as turbo, maf, egr etc share any controller wiring or if they all go back to the ecm on an individual basis?
Many thanks Mr. Green
Post #352062 17th Aug 2014 7:13am
K9F
Chapter 303-14 of the wiring diagrams. You go figure! If you don't have access to them use Dgardel's link.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #352065 17th Aug 2014 7:38am
munch90
are you having the codes read propeley or just scangauge or something similer
Post #352066 17th Aug 2014 7:39am
Caterham
I don't have any codes at the moment but my concern comes from my long standing intermittent problem and noticing my turbo actuator do a full movement while ticking over while I was jiggling the wiring.
Must get the lap top out later - cheers Mal.
Post #352068 17th Aug 2014 7:56am
Martin
Site Admin
Sensor and actuators generally do not have their own CAN connections (they are not "smart" actuators or sensors). There are exceptions though - but not on Puma.
On the Puma there is only a single CAN bus I believe, between the instrument pack and the engine ECU.
Think of CAN as a little like a wired computer network (it's a network after all).
You can connect computers (ECUs/modules) together using it.
Connected to those computers can be printers/scanners/webcams/keyboards/mice/etc (the sensors/actuators) which are not themselves directly on the CAN bus. However those devices or the results from them may be shared on the network, depending on how they need to be used by other computers on the network.
So going back to your original question, the sensor wiring has nothing to do with the CAN bus architecture. Each sensor/actuator on the engine is wired back to the engine ECU individually. There are some shared power and ground supplies for some of them.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #352072 17th Aug 2014 8:38am
Caterham
Many thanks.....and this reminds me to pack my multi meter for my hols.
Post #352093 17th Aug 2014 9:55am
martinfiattech
If your going to start investigating the can system, throw the multi meter in the bin and get yourself a scope and wave form guide.
As the vehicle is running I would leave the can network to it`s own devices. If the vehicle was more modern you could kill it by removing one wire Excuse the spelling I`am better with spanners and wires.
Post #352188 17th Aug 2014 7:41pm
Cuthbert
This thread has my full attention - I'm just waiting to see what happens next - Will it all end in tears or rejoicing.
Some topics are best left to the real experts
Post #352221 17th Aug 2014 9:41pm
Lorryman100
Wayne, take everyone's advice and stay away from the CAN network unless you know what you are doing. The only time I would use a DMM on the network is for an Ohms check, otherwise use a waveform oscilloscope like the 4 channel Pico scope. Thumbs Up
Taken from another post reference the CAN network.
Lorryman100 wrote:
As Pete has said you will need to terminate the Data Bus with a 120Ω terminating resistor, these resistors are used to terminate the network and to prevent signal reflections. You can also use these known resistor values to analyse the physical layer of the network for open and short circuits. The data bus (High speed 500k) only needs two and you can test the physical layer of the data bus with a digital multimeter by measuring across the CAN Low (-) and Can High (+), a good network connection should give a reading of 60Ω. (using Ohms law, 2 x 120Ω resistors mounted in parallel will produce a resistance value of 60Ω). On the instrument cluster plug, pin 16 is the CAN + (SJ6) and Pin 32 is CAN - (SJ5).
The other option is to use an oscilloscope to do a waveform analysis of the CAN network. This is where it can get slightly techy in the set up and use. The network bus speed is 500kbps so a 500µs time base is needed as is two channels, each set up at 5v to read the 2.5v signal of both CAN + and CAN - and this is seen by the ECU as a recessive state and is counted as a digital 1. So in the dominant CAN + the voltage will be 3.5v and the dominant state for CAN- will be 1.5v, this difference of 2v is seen by the ECU as a dominant state and counts this as a digital 0. Thumbs Up
Notice how both CAN+ and CAN- signals are both directly opposed? You can see the recessive state at 2.5v and the dominant state of CAN+ at 3.5v and CAN- at 1.5v.
Post #352229 17th Aug 2014 11:32pm
Caterham
Shocked
So back from hols and never got a chance to look into the wiring - probably just as well Laughing
All my spare time was taken up polishing Very Happy
Half way through cutting the lawns and thought I'd drop a quick question in before I do a big write up later which some may find interesting (most probably won't Mr. Green )
If I don't get the answer i'll be doing a search later after another test drive and before my write up Thumbs Up
Can anyone tell me what the middle connector / multi plug on the ecm is for?
Many thanks Thumbs Up
Post #354592 30th Aug 2014 3:53pm
K9F
303-14 - ELECTRONIC ENGINE CONTROLS in the wiring diagrams. Four pages detailing all the ECM (D131) connections.
Post #354606 30th Aug 2014 5:10pm
munch90
caterham , did it play up then ?
Post #354610 30th Aug 2014 5:26pm
Page 1 of 3 123>
