![]() | Home > Puma (Tdci) > the clever wiring |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6324 ![]() ![]() ![]() |
So the canbus stuff
Are the various sensors etc on a loop or are they all wired individually on radial circuits? Many thanks |
As an electrician who has experience with 1553 databus even I do not understand your question. A canbus can be a two way street to an individual or group of sensors or circuits so it sends signals and often expects something in return often on the same line. These return signals are differentiated from each other by seperate modulated frequencies or voltages that determine what sensor or circuit is responding and the information dealt with and processed accordingly.
It cannot be likened to a domestic installation with radial, spur or ring/loop like terminology. What is it exactly you are trying to achieve or wish to know? Try to be a little more specific. If this is yet another of your fog knitting, wild goose chase theories please don't expect an answer anytime soon! ![]() Treat every day as if it is your last....one day you will be right!! |
Just trying to understanding whether items such as turbo, maf, egr etc share any controller wiring or if they all go back to the ecm on an individual basis?
Many thanks ![]() |
Chapter 303-14 of the wiring diagrams. You go figure! If you don't have access to them use Dgardel's link.
are you having the codes read propeley or just scangauge or something similer
I don't have any codes at the moment but my concern comes from my long standing intermittent problem and noticing my turbo actuator do a full movement while ticking over while I was jiggling the wiring.
Must get the lap top out later - cheers Mal. |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6658 ![]() ![]() ![]() |
Sensor and actuators generally do not have their own CAN connections (they are not "smart" actuators or sensors). There are exceptions though - but not on Puma.
On the Puma there is only a single CAN bus I believe, between the instrument pack and the engine ECU. Think of CAN as a little like a wired computer network (it's a network after all). You can connect computers (ECUs/modules) together using it. Connected to those computers can be printers/scanners/webcams/keyboards/mice/etc (the sensors/actuators) which are not themselves directly on the CAN bus. However those devices or the results from them may be shared on the network, depending on how they need to be used by other computers on the network. So going back to your original question, the sensor wiring has nothing to do with the CAN bus architecture. Each sensor/actuator on the engine is wired back to the engine ECU individually. There are some shared power and ground supplies for some of them. ![]() ![]() |
Many thanks.....and this reminds me to pack my multi meter for my hols.
martinfiattech Member Since: 13 Nov 2013 Location: leicester Posts: 422 ![]() ![]() |
If your going to start investigating the can system, throw the multi meter in the bin and get yourself a scope and wave form guide.
As the vehicle is running I would leave the can network to it`s own devices. If the vehicle was more modern you could kill it by removing one wire Excuse the spelling I`am better with spanners and wires. |
Cuthbert Member Since: 26 Oct 2013 Location: Up North Posts: 1535 ![]() |
This thread has my full attention - I'm just waiting to see what happens next - Will it all end in tears or rejoicing.
Some topics are best left to the real experts |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Wayne, take everyone's advice and stay away from the CAN network unless you know what you are doing. The only time I would use a DMM on the network is for an Ohms check, otherwise use a waveform oscilloscope like the 4 channel Pico scope.
![]() Taken from another post reference the CAN network.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
![]() So back from hols and never got a chance to look into the wiring - probably just as well ![]() All my spare time was taken up polishing ![]() Half way through cutting the lawns and thought I'd drop a quick question in before I do a big write up later which some may find interesting (most probably won't ![]() If I don't get the answer i'll be doing a search later after another test drive and before my write up ![]() Can anyone tell me what the middle connector / multi plug on the ecm is for? Many thanks ![]() |
303-14 - ELECTRONIC ENGINE CONTROLS in the wiring diagrams. Four pages detailing all the ECM (D131) connections.
caterham , did it play up then ?
