Home > Maintenance & Modifications > Replacing front suspension
CFB
As I am planning on fitting a winch and bumper on my 110 I know that the front standard springs won't be up to the job, the front is already sitting much lower than the rear which I think is normal for the CSW.
Question is, can I just fit a pair of longer heavy duty springs and shockers to the front or do I need to do the rears too? Only looking at a 1.5" lift but the back looks high enough as it is. Andy
Post #29698 13th Apr 2010 12:05pm
Half a Job Andy Rolling with laughter
Post #29708 13th Apr 2010 1:04pm
MK
I fitted OME 751 and got 1.5". You can do a search on this forum as well about HD LR springs Puma 110" SW
Post #29709 13th Apr 2010 1:04pm
CFB
Will replace all 4 if req. just wondered if it was necessary Laughing Andy
Post #29712 13th Apr 2010 1:12pm
Andy only did the front on mine 1" thou and level her out but mine has OEM HD springs at the rear
Post #29714 13th Apr 2010 1:34pm
CFB
Are the HD rears the ones with another spring inside the main spring? Andy
Post #29717 13th Apr 2010 2:02pm
MK
NOT REALLY. HD REAR SPRINGS ARE JUST STIFFER. YOU CAN SET UP THE INNER ONES AS WELL. Puma 110" SW
Post #29718 13th Apr 2010 2:07pm
discocuzzy
Ahem, Who fitted the front ones Ken Whistle You cannot teach stupid people to do clever things
Post #29727 13th Apr 2010 3:47pm
Alex e
England 2006 Defender 110 Td5 DCPU Zambezi Silver
one of his workshop numpties i expect, or you........ Whistle same result tho Laughing
Post #29731 13th Apr 2010 4:04pm
