Home > Maintenance & Modifications > Replacing front suspension |
CFB Member Since: 13 Sep 2007 Location: Bradford, West Yorkshire Posts: 803 |
As I am planning on fitting a winch and bumper on my 110 I know that the front standard springs won't be up to the job, the front is already sitting much lower than the rear which I think is normal for the CSW.
Question is, can I just fit a pair of longer heavy duty springs and shockers to the front or do I need to do the rears too? Only looking at a 1.5" lift but the back looks high enough as it is. Andy |
13th Apr 2010 12:05pm |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
Half a Job Andy
13th Apr 2010 1:04pm |
Will replace all 4 if req. just wondered if it was necessary Andy
13th Apr 2010 1:12pm |
Andy only did the front on mine 1" thou and level her out but mine has OEM HD springs at the rear
13th Apr 2010 1:34pm |
Are the HD rears the ones with another spring inside the main spring? Andy
13th Apr 2010 2:02pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2432 |
NOT REALLY. HD REAR SPRINGS ARE JUST STIFFER. YOU CAN SET UP THE INNER ONES AS WELL. Puma 110" SW
13th Apr 2010 2:07pm |
discocuzzy Member Since: 16 Jul 2008 Location: surrey Posts: 1200 |
Ahem, Who fitted the front ones Ken You cannot teach stupid people to do clever things |
13th Apr 2010 3:47pm |
Alex e Member Since: 23 Apr 2007 Location: Home isn't it Posts: 204 |
one of his workshop numpties i expect, or you........ same result tho
13th Apr 2010 4:04pm |
