Home > Puma (Tdci) > Oil in air intake pipe?
HMARR
I removed the air intake pipe yesterday on the clean air side of my air filter box where it goes into the turbo and found oil in the pipe leading into the turbo. Is this normal?
Post #345714 16th Jul 2014 11:31pm
SiWhite
United Kingdom 2013 Defender 110 Puma 2.4 USW Stornoway Grey
Yes. There is a breather from the rocker cover into the intake pipe which vents excessive pressure - this carries oily air which leads to the oil you've found. My blog - www.anacreinhampshire.blogspot.co.uk
110 TD5 BuildHERE - sold!
110 Tdci Build HERE - sold!
Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender!
Post #345717 17th Jul 2014 4:20am
LR90XS2011
see the Provent thread on this forum,
I have now been running with the pipe from the rocker box to the clean air side of the filter removed , a filter added to the rocker box pipe and the clean air pipe blocked off . Done about 1000 miles and all good so far and I know I'm not passing oil through my turbo, inter-cooler, egr, inlet manifold etc etc. DEFENDER 90 TDCI XS,
Post #345720 17th Jul 2014 5:16am
K9F
As LR90XS2011 stated above. Provent filter fitted and it stops all the crud. In fact it was his I bought and fitted. As you've not an XS it is a straightforward fit but irksome with an XS due to the room taken up with ABS and aircon. Thumbs Up
http://www.defender2.net/forum/topic26798.html?highlight=provent If you go through life with your head in the sand....all people will see is an ar5e!!
Post #345723 17th Jul 2014 6:11am
HMARR
Ok, thanks guys. Will install one of those little oil catchment devices.
WHat would the effects be if I just left it?
Post #345999 18th Jul 2014 9:51am
K9F
Apart from oil vapour migrating into the intercooler and possibly 'carboning' up your turbo probably not a lot. Nevertheless it's down to personal choice and I think it's worth doing. Have a read below and make your own decision.....
Thumbs Up
http://www.westernfilters.net.au/mann-prov...separator/ If you go through life with your head in the sand....all people will see is an ar5e!!
Post #346006 18th Jul 2014 10:25am
