Home > Puma (Tdci) > Oil in air intake pipe? |
SiWhite Member Since: 19 Jan 2010 Location: North Hampshire Posts: 455 |
Yes. There is a breather from the rocker cover into the intake pipe which vents excessive pressure - this carries oily air which leads to the oil you've found. My blog - www.anacreinhampshire.blogspot.co.uk
110 TD5 BuildHERE - sold! 110 Tdci Build HERE - sold! Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender! |
17th Jul 2014 4:20am |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3645 |
see the Provent thread on this forum,
I have now been running with the pipe from the rocker box to the clean air side of the filter removed , a filter added to the rocker box pipe and the clean air pipe blocked off . Done about 1000 miles and all good so far and I know I'm not passing oil through my turbo, inter-cooler, egr, inlet manifold etc etc. DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
17th Jul 2014 5:16am |
As LR90XS2011 stated above. Provent filter fitted and it stops all the crud. In fact it was his I bought and fitted. As you've not an XS it is a straightforward fit but irksome with an XS due to the room taken up with ABS and aircon.
http://www.defender2.net/forum/topic26798.html?highlight=provent If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
17th Jul 2014 6:11am |
HMARR Member Since: 04 Jun 2013 Location: New Zealand Posts: 56 |
Ok, thanks guys. Will install one of those little oil catchment devices.
WHat would the effects be if I just left it? |
18th Jul 2014 9:51am |
Apart from oil vapour migrating into the intercooler and possibly 'carboning' up your turbo probably not a lot. Nevertheless it's down to personal choice and I think it's worth doing. Have a read below and make your own decision.....
http://www.westernfilters.net.au/mann-prov...separator/ If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
18th Jul 2014 10:25am |
