Home > Maintenance & Modifications > Windscreen Surround
ROBBONTHEROCK
Scotland 2007 Defender 110 Puma 2.4 XS CSW Firenze Red
Windscreen Surround
Hi folks,
Is it a big job to replace a windscreen surround, I've heard it's bolted to the roof and held onto the bulkhead essentially with the big fake hinges?
I have a 2001 Defender 110 CSW - TD5.
My windscreen surround is corroded, it's alloy I think and it's furring up, I'm planning on buying new windscreen blocks (croytek ones). I need to replace the windscreen seal and the window seal, I just want to make a proper job and try and head off potential issues in the future.
Any advice?
I tried searching the site, but couldn't see anything about removing the surround?
Andy
Post #344818 13th Jul 2014 6:52am
paulnb57
Remove faux hinges, remove headliner, unbolt roof from the top of the screen, also either unbolt the roof where the sides join the tub, or along the gutter (the roof needs to lift a bit as the screen surround locates on two pins at the bottom) release the top seal with knife, remove screen complete, refit new screen with new top and bottom seals, refit roof, trim etc
Paul
Post #344819 13th Jul 2014 7:08am
ROBBONTHEROCK
Cool, many thanks!!
Any idea how long to do?
Not sure I will actually go ahead with this, I just know that once I pull the windscreen and remove all the seals I might find a bigger problem, so just wanna know how big a job it is Wink
Any idea how long to do the work?
Andy
Post #344823 13th Jul 2014 7:56am
paulnb57
If your new screen is painted and in the screen surround ready to refit, I would allow one day, it probqbly wont take that long, but I dont know your skill level.......I would waxoyl or similar the ledge at the top of the bulkhed that the screen frame rests on while you are in there, after fitting the self adhesive seal, otherwise it wont stick, its not really difficult, just quite involved, especially removing the trim, theres aslo trim up the insides of the surround and wiring for the interior light to consider.......
Paul
Post #344829 13th Jul 2014 8:25am
ROBBONTHEROCK
Thanks for the info.
Sounds straight forward(ish)...........
Andy
Post #344861 13th Jul 2014 11:56am
