Home > Puma (Tdci) > Fitting an indicator light to show DPF regen? |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2232 |
Re alight, though I appreciate their can be many varients of trying to add a light to the car its probabally possibile that you can pick up from the CAN one of its messgaes for either the DPF or EGR postion during the dpf regen cycle. Inject that into a CAN node and re out put it to flash the mil lightevery 1 second during a regen or simlar.
Or limit torque or rpm during a regen so the driver will feel that its doing a regen, many many ways but all take time i think for possibily little gain to the car overall. Regards Pete |
12th Jul 2014 10:57am |
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 |
Looks like my hopes rest with Alive Tuning!
12th Jul 2014 11:43am |
Their as Alive said is not a lot in the engine ecu that is related to the dpf and lamp enablement especially for out putting it to a seperate lamp of the car so id assume without looking further and deeper it will be to be some in the middle compremise of notification somehow for the driver.
Pete |
12th Jul 2014 12:26pm |
Thanks Pete
12th Jul 2014 1:01pm |
Mynstral Member Since: 14 Feb 2012 Location: Essex Posts: 119 |
Hi all. Been having a think on this. Is it something a Scangage could be programmed to monitor?
Regards Myn. Smoke me a kipper I'll be back for breakfast. |
29th Jul 2014 10:08am |
Dunno. I just want a simple LED in the dash to tell me.
29th Jul 2014 10:19am |
pob1968 Member Since: 20 Apr 2014 Location: uk Posts: 239 |
Daft as it sounds could the power that feeds the DPF itself be just tapped into to supply a positive to a LED? I am an auto electrical numpty by the way - haven't got a clue but would like to have the light telling me if it's possible. 110 Hardtop
29th Jul 2014 11:26am |
That's what I was thinking too. No know nothing about 'code', a bit of solder and a LED is my limit!
29th Jul 2014 12:11pm |
Mjibex Member Since: 21 Mar 2013 Location: Reading Posts: 283 |
Or if not as simple as above - a temperature sensor of some sort - the temperature rise should be enough (above a certain temperature) to be indicative of attempted regen.
29th Jul 2014 5:26pm |
Juhulia Member Since: 11 Jul 2013 Location: Dresden Posts: 17 |
A ctrl light would be great for longer off-road trips.
Most of the short distance pilots are presumably animated to start collecting bonus miles I suppose that shorter oil change intervals are the best idea for futher investments into that "DPF thing". But I must say that after about 15k km there have not been any issues with that DPF. I suppose it would be clever to clean the DPF with grill cleaner after about 50k km, wouldn't it? |
2nd Aug 2014 7:37pm |
