Home > Puma (Tdci) > Clutch rattle/chatter? |
handbrake causing it ? think there was quite a bit on forum about
how many miles has it done? has anyone touched handbrake adjustment lately |
28th Jun 2014 7:33am |
schuee Member Since: 16 Jul 2012 Location: Lincolnshire Posts: 378 |
Mine did it from near enough new, my dealer adjusted it and touch wood it has never come back, I've nearly covered 50k now with just under 3 months warranty left.
Cheers Keith |
28th Jun 2014 6:19pm |
sparkylee Member Since: 06 Nov 2010 Location: surrey Posts: 1455 |
Yes mine did that from new
Adjust handbreak It's good to be back from the dark side DC110 -2012 Black with black hood and black x-tech FFRR 4.2 vogue Renault traffic auto PT crusier convertible Laika x700 Motorhome |
28th Jun 2014 10:25pm |
landys1 Member Since: 04 Dec 2013 Location: Cheshire Posts: 134 |
Thanks Guys, I'll take a look at this, cheers. 1959 Series 2 Ragtop
1989 SWB Stationwagon 1998 300Tdi Hard Top and 2012 2.2 Puma Hardtop (at work) 2011 Puma 90 2.4 XS |
29th Jun 2014 5:43pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17387 |
Mine has started doing exactly this since I replaced the transfer box. At the time I used the handbrake assembly from the new box since the old one was suffering from the usual Puma malaise of being full of oil! The new handbrake is adjusted tighter than the old (3 or 4 clicks as opposed to 6 or so) and I have the intermittent clunk. It is my intention to slacken it to see if that sorts it.
It sounds really serious when it clunks, doesn't it! |
29th Jun 2014 9:36pm |
Blackwolf, yes sounds bad, like something catastrophic is about to happen!
Does yours only do it when warmed up? Mine seems OK on short journeys, only happens after a long run.... 1959 Series 2 Ragtop 1989 SWB Stationwagon 1998 300Tdi Hard Top and 2012 2.2 Puma Hardtop (at work) 2011 Puma 90 2.4 XS |
30th Jun 2014 6:15am |
No, in fact if anything mine seems to be more prone to doing it at the start of a journey than when really warm! I don't see what else it could be though.
30th Jun 2014 7:59am |
When mine was doing it, it was always when it had warmed up so assume it was binding and after a journey if I felt the transmission brake drum it was very hot. Also heard it mostly when slowing down at junctions, and when stationery and clunking I found by slightly applying the handbrake the clunking would stop, so knew it was this at fault.
Keith |
30th Jun 2014 9:41am |
Right, I'll try the handbrake trick next time it happens, see if that stops it, which will help narrow down the cause. Hope this works, and it's not something more serious/clutch/transmission related! 1959 Series 2 Ragtop
30th Jun 2014 10:09am |
kimhas Member Since: 08 Feb 2013 Location: Norge Posts: 19 |
You find the problem? I have the same sound and problem, just the same, only when hot after a longer drive and only when coasting in low speed. I also thing it is the handbrake but havent done some thing yet. what is the solution? Relieve the handbrake slightly?
I drive a bit in lower speed and use the handbreak in hope that will help. MY2011 Defender 110 |
22nd Sep 2014 5:33am |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1917 |
Clutch springs loose, very common do a forum search 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
22nd Sep 2014 5:44am |
For info, my replacement transfer box and its associated handbrake have done about 8,000 miles since I fitted them in June and, now the rust has been cleaned off the drum and it has all bedded in, this knocking/banging/chattering noise has stopped. The handbrake lever also comes several more 'clicks' towards me when I apply it, and all is good.
22nd Sep 2014 8:11am |
