Home > Puma (Tdci) > Clutch rattle/chatter?
landys1
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Santorini Black
Hi, experienced this yesterday for first time, after a fairly long motorway (3 hr) drive.
When coasting up to traffic lights or queuing traffic, was getting a pronounced 'chatter' from transmission area.
Only happened when I depressed cluch (i.e coasting), not when in gear, and seemed to be getting worse as I drove - sounded horrible!
Any ideas? Vehicle is 2011 2.4 Puma 90, three months out of warranty Rolling Eyes 1959 Series 2 Ragtop
1989 SWB Stationwagon
1998 300Tdi Hard Top and 2012 2.2 Puma Hardtop (at work)
2011 Puma 90 2.4 XS
Post #341366 28th Jun 2014 7:31am
munch90
handbrake causing it ? think there was quite a bit on forum about
how many miles has it done?
has anyone touched handbrake adjustment lately
Post #341370 28th Jun 2014 7:33am
schuee
Mine did it from near enough new, my dealer adjusted it and touch wood it has never come back, I've nearly covered 50k now with just under 3 months warranty left.
Keith
Post #341464 28th Jun 2014 6:19pm
sparkylee
2012 Defender 110 Puma 2.2 DCPU Santorini Black
Yes mine did that from new
Adjust handbreak Thumbs Up It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech
FFRR 4.2 vogue
Renault traffic auto
PT crusier convertible
Laika x700 Motorhome
Post #341518 28th Jun 2014 10:25pm
landys1
Thanks Guys, I'll take a look at this, cheers. 1959 Series 2 Ragtop
2011 Puma 90 2.4 XS
Post #341642 29th Jun 2014 5:43pm
Mine has started doing exactly this since I replaced the transfer box. At the time I used the handbrake assembly from the new box since the old one was suffering from the usual Puma malaise of being full of oil! The new handbrake is adjusted tighter than the old (3 or 4 clicks as opposed to 6 or so) and I have the intermittent clunk. It is my intention to slacken it to see if that sorts it.
It sounds really serious when it clunks, doesn't it!
Post #341691 29th Jun 2014 9:36pm
landys1
Blackwolf, yes sounds bad, like something catastrophic is about to happen!
Does yours only do it when warmed up? Mine seems OK on short journeys, only happens after a long run.... 1959 Series 2 Ragtop
2011 Puma 90 2.4 XS
Post #341726 30th Jun 2014 6:15am
No, in fact if anything mine seems to be more prone to doing it at the start of a journey than when really warm! I don't see what else it could be though.
Post #341746 30th Jun 2014 7:59am
schuee
When mine was doing it, it was always when it had warmed up so assume it was binding and after a journey if I felt the transmission brake drum it was very hot. Also heard it mostly when slowing down at junctions, and when stationery and clunking I found by slightly applying the handbrake the clunking would stop, so knew it was this at fault.
Keith
Post #341764 30th Jun 2014 9:41am
landys1
Right, I'll try the handbrake trick next time it happens, see if that stops it, which will help narrow down the cause. Hope this works, and it's not something more serious/clutch/transmission related! 1959 Series 2 Ragtop
2011 Puma 90 2.4 XS
Post #341775 30th Jun 2014 10:09am
kimhas
Norway 2011 Defender 110 Puma 2.4 X-Tech LE Nara Bronze
You find the problem? I have the same sound and problem, just the same, only when hot after a longer drive and only when coasting in low speed. I also thing it is the handbrake but havent done some thing yet. what is the solution? Relieve the handbrake slightly?
I drive a bit in lower speed and use the handbreak in hope that will help. MY2011 Defender 110
Post #359369 22nd Sep 2014 5:33am
bear100
Clutch springs loose, very common do a forum search Thumbs Up 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #359370 22nd Sep 2014 5:44am
For info, my replacement transfer box and its associated handbrake have done about 8,000 miles since I fitted them in June and, now the rust has been cleaned off the drum and it has all bedded in, this knocking/banging/chattering noise has stopped. The handbrake lever also comes several more 'clicks' towards me when I apply it, and all is good.
Post #359390 22nd Sep 2014 8:11am
