Home > Puma (Tdci) > Good job I'm an enthusiast!!!!
Jas
07 Defender - work done so far.........
1.New Clutch- due to sharp gear changes
2.Driver's door re-aligned/resprayed-not shutting properly/white specks on door
3.Replaced Oil dipstick-difficult to remove
4.ECU software upgraded-revs increased about 200 revs when changing gear
5.Clutch bled/re-adjusted-not disengaging properly
6.Leaking swivel-both sides replaced
7.Modified oil sump fitted-as per bulletin
Only two visits to garage and vehicle has been colllected/replacement vehicle delivered both times so no problem.
Questions-
1.I've read that the engine/transmission has been lowered due to bearing wear-would this coincide with oil sumps hitting the prop-shaft's hence a modified sump??
2.I've had a new clutch/revised ECU software and the clutch is a lot better but when driving hard, the revs still increase when changing gear-anybody had similar experiences or found a solution? I have tried an 08 model which does the same.Is it something LR is looking into/have they sorted the problem?
3.Regarding the fuel breather pipe, has anybody had any problems/had it repositioned? I've noticed newer models are in a different place to earlier ones!
4.Has anybody experienced a whining noise coming from the engine/gearbox area on the cold mornings?Maybe gearbox/turbo but goes away when warm? Rolling Eyes Rolling Eyes
I think my Landy's an hypocondriac but it's still better than my old TD5!!!! Rolling with laughter
Post #1984 28th Apr 2008 7:55pm
Bogblaster
United Kingdom 2016 Defender 90 Puma 2.2 Adventure Corris Grey
Sadly you have to be an enthusiast to accept all of the faults, mine is about to have its 3rd turbo installed, the revs increasing on gear change is something I found that my driving naturally compensated for after a few hours by backing off the throttle a split second before the gearchange, but is is still annoying when someone else drives it.
I have had ABS problems, and have asked them to look at the clutch as I was concerend that having read about other people having to have new ones it was better to be safe and sure.
Overall it is a nicer drive than the old defenders, but it is a shame that the power is lacking in comaprison to a tuned TD5. 2019 MY Disco 5 HSE Lux
Audi A4 Avant 3.0L TDI Quattro - WOW
2016 90 Adventure
Post #1989 29th Apr 2008 8:34am
Jas
The only thing I miss from the TD5 is the sound of the engine, but don't miss the gearchange, misty windows, and revving it's nuts off.
I'm sure with all the problems of the 07 Defender clutch, they'll change it anyway. The problems raised with this model does paint a negative picture but unless I'd been made aware of them, would probably not have noticed. To keep things in perspective, I see this website as a useful tool to highlight and resolve potential problems at an early stage. It's still a fantastic vehicle, and you'll get problems with any vehicle, Japanese whatever!
Post #1996 29th Apr 2008 8:13pm
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
[quote="Jas"]The only thing I miss from the TD5 is the sound of the engine, but don't miss the gearchange, misty windows, and revving it's nuts off.
Couldn't agree more !! Love the sound and power of a tuned TD5.
The perfect defender 2007 model , with Tuned TD5 engine Very Happy
Nidge.
Post #1998 30th Apr 2008 7:22am
jst
Re: Good job I'm an enthusiast!!!!
Questions-
in answer to Q1 i believe the T box has been rotated 90deg on a 08MY but thats only hear say cant say i have checked one to confirm yet. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #2005 30th Apr 2008 5:07pm
walfy
James
It has been rotated but I don't think it's 90deg 110 D250 SE HT
110 USW SOLD
Polaris RZR 900XP SOLD
Post #2006 30th Apr 2008 6:24pm
jst
ok, i was going off what you said anyway, will check when we get one in work probably next month i reckon Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #2007 30th Apr 2008 6:35pm
walfy
When I spoke to D44 at your event they mentioned it had been rotated slightly. The transfer box now hangs BELOW the chassis rails, unlike before when it was inside so to spk. The h/brake drum is also very low 110 D250 SE HT
110 USW SOLD
Post #2008 30th Apr 2008 8:14pm
Petrovich
Russia
First of all I'm that happy owner, who don't bother about quality. But whats really ennoing - its a time cosuming (waste for better word) 30th Aprl its confirmed Clutch has to be replaced. When? Garranty engeneer has no idea 'cos LR slow to supply spares to Russia (3d market after UK and US). Now dealler is trying to find the clutch at Ford!!! Very Happy Very Happy Very Happy Good news while waiting I still ride my motorcycle but bad one its a Harley Very Happy Defender 110 '07
Post #2048 7th May 2008 8:17am
R380
Ireland 2008 Defender 90 Puma 2.4 HT Tonga Green
Gearbox /clutch gremlins ?
08 puma 90 with 6k done ; gearbox can be a bit notchy and rattles slightly also if clutch is let in while coasting to a stand still. i some times get a clunk when changing fron 4 -5 ( Like the mainshaft R380 death clunk from my old 300tdi disco that cost me some time ago Sad ) but not when changing gear in any other sequence. Love the car , but it does sound like a bag of bolts compared to my previous TD5. humour is that delicious perception of incongruity from a vantage point of ease and superiority...
Post #2056 7th May 2008 10:37pm
Laurie
I've just had my '05 TD5 D90's spigot bush replaced (under warranty) with a 'modified' version after having trouble changing from 1st to 2nd when cold.
I was told 'There is a problem'. (Apparently they can break up.)
Post #2057 8th May 2008 12:05am
Daniel TD5
United Kingdom 1986 Defender 90 Other ST Nato Green
i have a 07 xs double cab
i have had mayor problems with the gear box and clutch have had a new clutch fitted
but after a hour or so of driving its sounds like the gear box is breaking up when slowing up loud banging come from below when not in gear and rolling with clutch depress or in gear all the same
very loud bangs when changing gear not had a ecu up grade seems to be a clutch problem gearbox problem
dan
Post #2058 8th May 2008 11:21am
Andrea
RE: Revs after gear change.
Simple fix to solve the reving, its the fuse for the trailer connector. Check all the fuses, you will find a blown one-change and youll be 100%
Post #47044 2nd Dec 2010 11:05am
