Home > My Defender > Bit more progress on the soft top conversion.
Page 2 of 3 <123>
Fullfat
1999 Defender 90 Td5 HT Rioja Red
Here's the proof for my new Landrover wing badges,
Personally I love them,
Have chosen the one on the left and they will be handed for each wing
Post #337786 12th Jun 2014 5:05pm
Fullfat
After some head scratching and swearing progress has moved on a little
Post #338243 15th Jun 2014 1:23pm
SailingTom
Looking really good Thumbs Up
Its becoming like the car I almost made (and should of with a td5, very jealous of that chassis to) Thumbs Up Defender puma dormobile camper
Post #338347 15th Jun 2014 8:58pm
garethmorgan50
How did the speedliner come out? have you got any pictures to show it?
Post #338714 17th Jun 2014 11:34am
Fullfat
A few speedliner photos for Gareth Morgan 50
Post #338810 17th Jun 2014 7:18pm
mikeh501
I like the speed liner. How much did you pay etc?
Also my roll cage turned up and looks identical to yours!
Post #338860 17th Jun 2014 9:15pm
Fullfat
Where did you get you hoop set from mikeh?
Post #338861 17th Jun 2014 9:19pm
mikeh501
All wheel trim. They supplied everything.
Post #338862 17th Jun 2014 9:24pm
Fullfat
Yes I dealt with Kim for my hood, very helpful, still haven't fitted mine yet, have you gone for the tenex fittings For the hood?
I got the mohair hood in sand with side windows, very well built and will get it fitted this weekend.
38 holes to dril and tap for the hood fixings!
Post #338864 17th Jun 2014 9:27pm
mikeh501
Went for the cheaper rope down hood with Black mohair with no side windows. Wish I had ordered sand now with zip up sides etc Smile maybe next year if I like it.
Took the roof off on Sunday afternoon. Since then I've been doing a little repair the cappings to tidy them up as they have a bit of surface rust. Sand down tomorrow, then final primer coat tomorrow evening. Stick some top coat on Thursday. Can then start bolting up the cage etc.
You had any snags so far?
Also was yours a hardtop previously? What are you telling the insurance?
Post #338866 17th Jun 2014 9:34pm
Fullfat
Mine was a pickup which was listed as pickup/softtop on the log book so no issues with insurance.
Only issues I found was getting the doors to line up, big hint loosen the windscreen brackets first and then tighten these last.
Also lining up door shuts took an age.
If you have the clamp down header bar the gasket goes in the square groove, this is far from obvious.
Apart from that don't be surprised if your holes don't line up and need re drilling when you bolt the hoop set down mine where all half a hole out.
Trouble is when you strip everything out you end up rebuilding the Landrover !!
Post #338868 17th Jun 2014 9:40pm
garethmorgan50
The speed liner looks really good, are you happy with it?
Post #338875 17th Jun 2014 10:09pm
Fullfat
Yes very happy with the speedliner it's made a huge difference to the internal finish and is very hard wearing, I'm told it shouldn't wear during normal wear and tear but only time will tell.
It is also very forgivening in terms of what it covers up so yes very happy with it Mr. Green
Post #339090 18th Jun 2014 9:45pm
mikeh501
hey fullfat,
what came with your heavy duty bar set? I started to unpack mine and found some bolts etc, but couldnt see any type of strengthener for where the nut will be underneath the capping? did you just use big penny washers? Can you share a photo of what it looks like underneath the bolt points of your cappings pls Smile
Post #339368 20th Jun 2014 7:49am
Fullfat
Hi you use the big penny washers for the fixing of the bars to the tub, the 20mm smaller washers are for the door sides and head.
My holes didn't line up, Landrover tolerances !!
Can send a few pictures tonight once home.
I'm assuming you got a fixing kit with yours?
Thanks
Post #339385 20th Jun 2014 9:07am
Page 2 of 3 <123>
