Home > My Defender > Bit more progress on the soft top conversion.
Page 3 of 3 <123
Fullfat
1999 Defender 90 Td5 HT Rioja Red
mikeh501 wrote:
hey fullfat,
what came with your heavy duty bar set? I started to unpack mine and found some bolts etc, but couldnt see any type of strengthener for where the nut will be underneath the capping? did you just use big penny washers? Can you share a photo of what it looks like underneath the bolt points of your cappings pls Smile
Mike let's see some photos of your soft top in progress.
Post #339391 20th Jun 2014 9:25am
mikeh501
no probs. im taking pics as a i go along. ive created a build thread already so you can see where I was up to about 12 months ago! i need to bring the story up to date with my current soft tops mods ! Mr. Green
Post #339411 20th Jun 2014 11:13am
mikeh501
Post #339413 20th Jun 2014 11:14am
mikeh501
one to whet your appetite. these are my new series door bottoms and rocky mountain ali door tops. Lovely bit of kit.
Post #339415 20th Jun 2014 11:18am
mikeh501
Cage was easy. Door surrounds a complete nightmare! Do you vertical door surround pieces match to the holes on the cage? The bottom one is way out and it looks like the bottom slanted rain run off needs bending! One for tomorrow but any tips welcome!
Post #339712 21st Jun 2014 6:20pm
Fullfat
Mikeh501
Hi yes I needed to bend the bottom of the door shut mine never lined up even after bending they were still 8 mm out of line with the track the rubber seal pushes onto, doesn't seem to matter as after a week of the door being shut it works a treat now with no further adjustments.
Have just finished fitted the hood with the tenex fittings, you have saved yourself some grief not using them!
Post #339723 21st Jun 2014 8:03pm
mikeh501
Did you need to drill a new hole to fit the lower bolt from the vertical door surround so it matches up to the cage hoop?
Post #339724 21st Jun 2014 8:15pm
Fullfat
No they should line up with plenty to spare as there slotted.
Post #339725 21st Jun 2014 8:19pm
Fullfat
Post #339726 21st Jun 2014 8:23pm
Fullfat
Post #339727 21st Jun 2014 8:25pm
Fullfat
Took the 90 out for its first proper drive since I took it all apart and put it back together again.
Stopped on way for a few arty photos!!
Q
Post #339863 22nd Jun 2014 5:21pm
SailingTom
Very nice definitely looks like it was worth the time and effort. Look forward to seeing it, well done so far Very Happy Defender puma dormobile camper
Post #339869 22nd Jun 2014 5:46pm
Fullfat
Next week new shocks springs and bushes, and on the look out for some new seats also.
Been hard work but enjoyable and rewarding, got some Thumbs Up from fellow Landy drivers on way to stamford this morning made my day. Mr. Green
Post #339872 22nd Jun 2014 5:59pm
mikeh501
Really nice ! Mine is also now complete! Took some serious hours thus weekend Smile
Post #339962 22nd Jun 2014 9:50pm
Fullfat
Getting excited after 4 weeks in the body shop my complete strip down and respray is finished, I have replaced every nut and bolt replaced all the panels except the bonnet, fitted new series doors and Rocky Mountain door tops, new door hinges and bonnet hinges, windscreen hinges, fitted new grills and led headlights. It's almost a brand new 15 year old Landrover hopefully picking it up Saturday if time and will post a few pictures of the finished result, been a labour of love but to anyone thinking of doing one it's worth it.
Post #355404 3rd Sep 2014 5:49pm
Page 3 of 3 <123
