![]() | Home > Puma (Tdci) > Does an EGR still clean when switched off?? |
yes agree no point in remap with faulty valve
cooler side ( the bigger openning ) with two 10mm headed bolts , if you get the blank with the slotted holes you just loosen the bolts and slide it in
Dieselhead Member Since: 21 Oct 2012 Location: Pulborough. West Sussex Posts: 552 ![]() |
Thanks Munch
![]() Going to have to fit a new valve as squeeking loud when it does clean cycle. I will make a blank plate when its off ![]() 2008 XS 110 2.4 Utility. Tonga Green 1953 Series 1 for restoration 1983 Mini Mayfair 2004 VW T5 Camper 2008 Diahatsu Sirion. Thats hers Classic Bolens Garden Tractors |
fleabay about £3.50
fatman Member Since: 14 Jan 2014 Location: Athens-Greece Posts: 126 ![]() ![]() ![]() |
so people,you mean that whatever method we apply(deactivation,unplugging etc),there is a chance the valve will open from exaust gas pressure? How come it stays closed when needed in stock-unmodified form,i don't understand..
it cant open from exhaust pressure
Fitted a new EGR & Blank plate yesterday.
Took for a test & all seems fine ![]() We will see Thanks Chris 2008 XS 110 2.4 Utility. Tonga Green 1953 Series 1 for restoration 1983 Mini Mayfair 2004 VW T5 Camper 2008 Diahatsu Sirion. Thats hers Classic Bolens Garden Tractors |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8208 ![]() ![]() ![]() |
all very interesting could someone post up a picture of where the blank goes please, and its location. Cheers
Quick search reveals.....
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
cheers
is that at the back of the block? against the bulkhead? Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Yep.
Thats where I put mine. You cant go wrong as the plate only goes on one pipe My plate has no holes Chris 2008 XS 110 2.4 Utility. Tonga Green 1953 Series 1 for restoration 1983 Mini Mayfair 2004 VW T5 Camper 2008 Diahatsu Sirion. Thats hers Classic Bolens Garden Tractors |
JohanG Member Since: 09 Jul 2014 Location: Walvis Bay Posts: 1 ![]() ![]() ![]() |
I removed my EGR valve, open it up on top, removed the two drive gears, close up and install back. so the drive motor still get power but no gears to open up valve. The valve open up on a spring, so when power is cut the valve close. I also cut the small pipe to intake and weld both ends. I done now 4000km without any warning lights, this is now 4 weeks on running without EGR valve.
I just reload the standard map every few months to let it clean itself for a few days. The EGR has to continue to function anyway or it will fail the TÜV Tell someone you love them today because life is short.
But shout it at them in German because life is also terrifying and confusing... |
Since my egr was playing games and eventually pulled the plug,i'll try the same!! |
