Home > Puma (Tdci) > Does an EGR still clean when switched off??
Page 2 of 3 <123>
munch90
yes agree no point in remap with faulty valve
Post #336959 9th Jun 2014 6:21pm
Dieselhead
Thanks for the info Thumbs Up
Which side should you fit a blank plate on a puma please Confused Sure I have seen a pic some where Embarassed Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #337023 9th Jun 2014 9:19pm
munch90
cooler side ( the bigger openning ) with two 10mm headed bolts , if you get the blank with the slotted holes you just loosen the bolts and slide it in
Post #337027 9th Jun 2014 9:23pm
Dieselhead
Thanks Munch Thumbs Up
Going to have to fit a new valve as squeeking loud when it does clean cycle.
I will make a blank plate when its off Cool unless you know where I can buy one? Chris
1983 Mini Mayfair
2004 VW T5 Camper
Post #337029 9th Jun 2014 9:27pm
munch90
fleabay about �3.50
Post #337032 9th Jun 2014 9:35pm
fatman
Greece 2007 Defender 110 Puma 2.4 USW Keswick Green
so people,you mean that whatever method we apply(deactivation,unplugging etc),there is a chance the valve will open from exaust gas pressure? How come it stays closed when needed in stock-unmodified form,i don't understand..
Post #337297 10th Jun 2014 8:21pm
munch90
it cant open from exhaust pressure
Post #337306 10th Jun 2014 8:36pm
Dieselhead
Fitted a new EGR & Blank plate yesterday.
Took for a test & all seems fine Thumbs Up
We will see
Thanks Chris
1983 Mini Mayfair
2004 VW T5 Camper
Post #338388 16th Jun 2014 6:21am
jst
all very interesting could someone post up a picture of where the blank goes please, and its location. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #338409 16th Jun 2014 9:21am
K9F
Quick search reveals.....
AndrewS wrote:
Here is a picture of what you are blanking off
Wider view
Now I have seen the configuration of the holes in the tube TBH I don't think there will be much difference between drilling a 5mm � hole or a 10mm � hole. I have drilled my blanking plate out to 19mm �
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #338462 16th Jun 2014 2:10pm
jst
cheers
is that at the back of the block? against the bulkhead? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #338545 16th Jun 2014 7:44pm
Dieselhead
Yep.
Thats where I put mine. You cant go wrong as the plate only goes on one pipe
My plate has no holes Chris
1983 Mini Mayfair
2004 VW T5 Camper
Post #338548 16th Jun 2014 7:51pm
JohanG
Namibia 2010 Defender 110 Puma 2.4 HCPU Alpine White
EGR Blanking
I removed my EGR valve, open it up on top, removed the two drive gears, close up and install back. so the drive motor still get power but no gears to open up valve. The valve open up on a spring, so when power is cut the valve close. I also cut the small pipe to intake and weld both ends. I done now 4000km without any warning lights, this is now 4 weeks on running without EGR valve.
Post #348133 28th Jul 2014 10:00pm
ZeDefender
I just reload the standard map every few months to let it clean itself for a few days. The EGR has to continue to function anyway or it will fail the T�V Tell someone you love them today because life is short.
Post #348184 29th Jul 2014 10:22am
fatman
Re: EGR Blanking
Since my egr was playing games and eventually pulled the plug,i'll try the same!!
Post #348388 30th Jul 2014 2:10pm
Page 2 of 3 <123>
