Home > Technical > Radio code for PUMA |
sasha2001 Member Since: 02 Jan 2009 Location: New Zealand+ russia Posts: 206 |
Hi I have a 2008 puma 110 csw, the dealers replaced the clutch and somehow stuffed the radio code
When I press the power button it gives a message after about 2 seconds of: 3cde err then goes to safe I found two radio codes in the stuff I got so someone must have replace the radio and not put it in the dealers network system!! How do I re enter the code? any help appreciated |
26th Mar 2010 7:39am |
Sasha,
Have a look here; http://www.defender2.net/forum/topic2015.h...radio+code Always worth doing a search before posting. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
26th Mar 2010 7:48am |
cheers for that ALL sorted out I had searched but only looked at the first page!!! of course mine is in safe mode so the instructions for entering would not work, I will try , otherwise I will give the dealer the two codes and they can try, if not they can replace the radio!!!!!
26th Mar 2010 6:39pm |
