![]() | Home > Technical > Radio code for PUMA |
sasha2001 Member Since: 02 Jan 2009 Location: New Zealand+ russia Posts: 206 ![]() ![]() ![]() |
Hi I have a 2008 puma 110 csw, the dealers replaced the clutch and somehow stuffed the radio code
When I press the power button it gives a message after about 2 seconds of: 3cde err then goes to safe I found two radio codes in the stuff I got so someone must have replace the radio and not put it in the dealers network system!! How do I re enter the code? any help appreciated |
Sasha,
Have a look here; http://www.defender2.net/forum/topic2015.h...radio+code Always worth doing a search before posting. ![]() ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
cheers for that ALL sorted out I had searched but only looked at the first page!!! of course mine is in safe mode so the instructions for entering would not work, I will try , otherwise I will give the dealer the two codes and they can try, if not they can replace the radio!!!!!
