Home > Technical > Radio code for PUMA
sasha2001
Russia 2008 Defender 110 Puma 2.4 CSW Tonga Green
Radio code for PUMA
Hi I have a 2008 puma 110 csw, the dealers replaced the clutch and somehow stuffed the radio code
When I press the power button it gives a message after about 2 seconds of: 3cde err then goes to safe
I found two radio codes in the stuff I got so someone must have replace the radio and not put it in the dealers network system!!
How do I re enter the code? any help appreciated
Post #28076 26th Mar 2010 7:39am
K9F
Radio Code!
Sasha,
Have a look here;
http://www.defender2.net/forum/topic2015.h...radio+code
Always worth doing a search before posting. Thumbs Up Dog Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #28077 26th Mar 2010 7:48am
sasha2001
cheers for that ALL sorted out I had searched but only looked at the first page!!! of course mine is in safe mode so the instructions for entering would not work, I will try , otherwise I will give the dealer the two codes and they can try, if not they can replace the radio!!!!!
Post #28161 26th Mar 2010 6:39pm
