Home > Maintenance & Modifications > Provent fitting woo's
Page 1 of 4 1234>
df1
I fitted the provent to my td5 about a month ago.
Did 2 trips of about 6 hours driving, it burnt about 1 litre of oil each time.
Never had to top up once between oil changes since new.
Thought it might be my turbo on the way out but there's very little play in the turbine, I removed the provent today and did a 4 hour round trip, not a tint of oil burned.
When I fitted the provent I brazed a pipe into the turbo return pipe for the return from the provent, could this be an issue ?
Really has me baffled, went from not using a tint of oil to drinking it back to not using a tint.
Post #331820 18th May 2014 6:42pm
K9F
Was the filter and the inside of the Provent housing wet with oil? It sounds on the face of it that you have managed to rig up some form of syphon rather than a filter. I am unaware of the setup on a TD5 but on my Puma I effectively in laymans terms cut the crankcase breather and fitted the Provent in series. Where did your crankcase breather return feed to before you brazed it into the turbo return pipe?
***EDIT***
A couple of TD5 owners here have bought them and presumably fitted them too. Drop them a 'pm' and ask how they fitted theirs.
Thumbs Up
http://www.defender2.net/forum/topic26798.html?highlight=provent If you go through life with your head in the sand....all people will see is an ar5e!!
Post #331847 18th May 2014 7:50pm
df1
My Worthing May not be the best,
I simply disconnected the original breather pipe where it fits onto the valve on inlet pipe just after turbo.
Connected that to inlet on provent, then put a new pipe from outlet on provent to valve where breather pipe was previously.
Effectively just putting the provent inline on original breather pipe.
I then connected the small pipe out of the bottom of the provent to the oil return pipe from the turbo.
Just can't figure out what's wrong.
Post #331866 18th May 2014 8:16pm
LR90XS2011
I think the problem is where you have the oil return from the provent, as it allows the vacuum from the engine to draw oil from the turbo return. The drain from any seperator should go to a point below the level of the sump oil. An alternative is just to have it going to a sealed catch tank. Also dont forget that the oil return pipe from the turbo may still actually be under pressure from the oil supply to the turbo.
as an aside I have now fitted a 200tdi seperator to my puma to see if actually catchs anything, I will let everyone know how it goes. DEFENDER 90 TDCI XS,
Post #331869 18th May 2014 8:28pm
K9F
Just blank off the small pipe at the bottom of the Provent there's no need to return feed the oil as they don't need draining very often anyway. I think your issue lies there.
RockJaw wrote:
We don't drain ours more than once every 20k-30k (kms that is, not miles)
Post #331879 18th May 2014 9:07pm
df1
Thanks for the help.
I'll try fitting it without the return in the morning.
Post #331884 18th May 2014 9:20pm
LR90XS2011
Im fairly sure as Mal and I both have suggested that will be your fix. DEFENDER 90 TDCI XS,
Post #331939 19th May 2014 6:25am
Steve B
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
I have done this, I wouldn't want to use this oil again anyway and as Mal says there is very little.
I believe the Provent manufacturers suggest a one way valve?
Steve
Post #332111 19th May 2014 8:10pm
K9F
Due to the close location to the turbo I fitted a steel braided drain pipe to my Provent and my one way valve is an M10 bolt with a small jubillee clip at the end of it. With the mileage I cover it'll be a few years before I'll have to drain it anyway.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #332150 19th May 2014 10:13pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
How have others mounted there provent on a Td5? Mines a XS and abit tight for room.
Regards
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #332188 20th May 2014 7:15am
K9F
Derbywill,
Mine's an XS albeit a 2.4 but it was damn tight for fitting on mine too. Maybe you could utilise my idea of a bracket and 'p' clip arrangement and adapt it for your TD5 perhaps?
Page 5.....
http://www.defender2.net/forum/topic26798-60.html If you go through life with your head in the sand....all people will see is an ar5e!!
Post #332228 20th May 2014 9:44am
ibexman
Can someone post up plumbing diagrams ? Thumbs Up
Post #389380 17th Jan 2015 2:54pm
K9F
Have a look at the linked thread there's some photos on there that will give you a guide. There's only two pipes to connect you basically in layman's terms cut the rocker breather pipe and fit the Provent in series blanking off the oil return pipe outlet at the bottom of the Provent. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #389389 17th Jan 2015 3:11pm
ibexman
Cheers Mal
Post #389391 17th Jan 2015 3:16pm
K9F
Take a note of the TD5 issue above, no need to connect the oil return. You should have loads of room too which is a bonus. Thumbs Up
I know mine's a Puma but you can see clearly the rocker breather connected to the inlet of the Provent.
The outlet depicted as the lower pipe with the blue 90 degree union is the outlet which is basically the other half of the cut breather pipe. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #389395 17th Jan 2015 3:22pm
Page 1 of 4 1234>
