Home > Puma (Tdci) > Transfer Box Oil
Page 2 of 2 <12
Diablo
1984 Defender 90 200 Tdi SW Keswick Green
shaggydog wrote:
Diablo- Think that only applys to the Gearboxes not the transfer box but i could be incorrect there I'm sure someone will correct me!
Sounds about right, couldn't remember which one it was on these new fangled Defenders!
Post #329671 9th May 2014 3:34pm
Phil_D
Ah, yes, I see it now; I hadn't got beyond the summary table which doesn't refer to the transfer box at all! I've just found a note on page 73 which says:
CAUTION: The transfer case oil filler plug must not be used as a transfer case oil level plug. Failure to follow this
instruction may result in damage to the vehicle.
So it's a measured 2.3 litres.
Thank you!
Phil.
Post #329674 9th May 2014 3:42pm
ronwong
2012 Defender 110 Puma 2.2 SW Orkney Grey
someone told me never to drain the transfer case, and it probably wont need changing, just checking and top up with necessary. Is that a myth? I have never heard of any oil that is better off dont changing...
Post #346449 20th Jul 2014 11:16am
ericvv
Post #346458 20th Jul 2014 11:38am
Page 2 of 2 <12
