Home > Puma (Tdci) > Transfer Box Oil |
Phil_D Member Since: 09 May 2014 Location: Perthshire Posts: 25 |
Ah, yes, I see it now; I hadn't got beyond the summary table which doesn't refer to the transfer box at all! I've just found a note on page 73 which says:
CAUTION: The transfer case oil filler plug must not be used as a transfer case oil level plug. Failure to follow this instruction may result in damage to the vehicle. So it's a measured 2.3 litres. Thank you! Phil. |
9th May 2014 3:42pm |
ronwong Member Since: 28 Jun 2012 Location: Singapore Posts: 120 |
someone told me never to drain the transfer case, and it probably wont need changing, just checking and top up with necessary. Is that a myth? I have never heard of any oil that is better off dont changing...
20th Jul 2014 11:16am |
^^myth. I change mine once per year. You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
20th Jul 2014 11:38am |
