Home > 130 > It's started, Longshanks will no longer be a Pick up
Page 3 of 13 <123 4 ... 111213>
110 DC is not the same, since the upsweep of the chassis to clear the rear axle is in the way. Big Cry
The 130 has a completely flat floor in the second row area, to which is bolted a 110 seat box. Result, a huge wasted empty space enclosed in a big empty aluminium can, to resonate and make noises.
That NS C post mod for the door catch is an eye-opener! I know that if I measure my 110 DC one side of the vehicle is approx 15 mm longer than the other.
Edit - correction - it is not a standard 110 seat box - it is narrower and squarer. Makes it even more inexplicable!
Post #330488 12th May 2014 8:51am
MuddyChris300tdi
United Kingdom 1995 Defender 130 300 Tdi HCPU Alpine White
Well my girlfriend has just had to get the wet and dry vac out as I've been drooling over your 130's. They are all so well build and modded.
Chris.
Post #330638 12th May 2014 7:32pm
Sphere
United Kingdom 2015 Defender 110 Puma 2.2 USW Keswick Green
Bow down
Post #330642 12th May 2014 7:43pm
Maxxed_Ross
Scotland 2001 Defender 90 Td5 CSW Cobar Blue
good thing you said that before I cut mine off to find out Laughing
Post #330704 13th May 2014 7:10am
Aquarius0
Poland
When are you planning to show the end effect of the transformation?
Waiting for more photos Very Happy Don't drive faster then your guardian angel can fly...
Post #330726 13th May 2014 9:41am
AndrewS
Been very busy at work so not had chance to work on Longshanks, however yesterday I managed to move the 2nd row seats back by 130mm giving a fair bit more leg room. (pics to follow) although you can see the reduced seat box in the second pic.
I also started on the body to tub mating plate. This in an 8mm thick hi grade ally plate that will be cut into a big U shape, here you can see it in place waiting to be marked up prior to being cut into shape.
Post #335308 2nd Jun 2014 7:43pm
Looking good Andrew, I can't wait for the next installment!
Is this how you did the conversion on J-Lo, or are there improvements based on what you learned last time?
Post #335324 2nd Jun 2014 8:31pm
AndrewS
Yea same thing sort of thing, but this time I'm being a bit more er ........ lets make use of the wasted space.
Post #335330 2nd Jun 2014 8:57pm
AndrewS
I cut out the 'adapter plate' today and welded a support angle to it Thumbs Up
The tub is off having the front posts welded in 'up right'.
As the tub is off I will change the rear springs and shocks tomorrow.
Post #335520 3rd Jun 2014 8:02pm
mick
England 2010 Defender 130 Puma 2.4 HCPU Rimini Red
Looking good Andrew Thumbs Up
Ether thought off offering Land Rover a bid for the production line cos you make a better job than they do
Whistle
Post #335556 3rd Jun 2014 9:27pm
AndrewS
Laughing Laughing
Must say that it would be quicker and easier if I had bought a rolling chassis and the body in kit form.
Post #335561 3rd Jun 2014 9:37pm
AndrewS
Here is a pic showing the 'leg room' that is now available in the second row floor area.
To give a comparison the mat in the foot well is from a 110
Post #335768 4th Jun 2014 7:24pm
AndrewS
Leap of faith this afternoon........ measured and measured and measured again before marking out the brand new 90 roof ready to cut off the bit that's not required.
Too late now here is the 'off cut' (and Thomas the SpringerBear)
Here you go if fits TF Whistle still got to cut the gutter to suit but its there Thumbs Up
Post #337007 9th Jun 2014 7:42pm
keith
Great topic and I watch with great excitement to see the finish .
I will be taking the leap of faith ( and the cutter ) to my new 110 2.2 xs csw soon . Going to be daring .
Windscreen out and replaced for a split screen
Doors off , replaced with series and military tops
Hardtop off and replaced with full canvas . Hmmmmm !
Post #337013 9th Jun 2014 8:06pm
AndrewS
Starting to get annoying now, not only is the vehicle not square nor is the AFN top Twisted Evil
The amount of times I have lifted the new roof on and off is unbelievable, hopefully by the end of the day I will have made the roof to roof adapter plate and the side to side ones.
Its booked into the spray shop for next Thursday so I have to get this sorted today Shocked Plus the fact that I am off to Barcelona tomorrow to watch the MotoGP.
Post #337648 12th Jun 2014 7:00am
