Home > 130 > It's started, Longshanks will no longer be a Pick up
Page 11 of 13 <123 ... 10 111213>
AndrewS
Started on the rear shelving, as I expected nothing in the rear tub is level/straight/parallel so its going to take some sorting to get things to at least look straight.
 130's have feeling's as well you know Smile
Post #417062 18th Apr 2015 2:58pm
S17ech
Back
Have you made the back yourself or had it made for you
Post #417327 19th Apr 2015 5:59pm
AndrewS
Got the compressor, air tank, inverter and right hand cargo rail mounted today.
Post #419200 26th Apr 2015 4:53pm
AndrewS
Made the base for the water tank.
Also started mating the Defender trim the rear.
Post #426214 25th May 2015 7:59pm
johnszs
United Kingdom 2004 Defender 90 Td5 XS CSW Alveston Red
Very nice Mr S Thumbs Up 2004 TD5 Defender 90 xs station wagon
Post #426467 26th May 2015 7:32pm
Greggster
United Kingdom 2007 Defender 110 Puma 2.4 HT Alpine White
Superb thread and build Bow down Very very clever stuff Bow down
Post #426486 26th May 2015 8:16pm
Rosso_NI
United Kingdom 1993 Defender 110 2.5 n/a Diesel ST Galway Green
Great work as always Bow down
Post #427198 30th May 2015 8:03am
Roz Dev
Ireland 2015 Defender 110 Puma 2.2 SW Keswick Green
What a great build, some great engineering going on there! Thumbs Up
Post #427308 30th May 2015 9:24pm
AndrewS
Sorry I have been quiet on here, got the usual very busy at work excuse which is great Razz We have also got the builders in replacing the roof on my house, the removal of the concrete render, new windows and doors and interior works involving the removal of old lath and plaster ceilings etc etc.
Here is a pic of the front of the house with the render removed Shocked
So Longshanks is not being worked on but is at work ferrying kit about.
I can confess that I did go out for a play Sunday just gone.
Oh the Bowler breaks are now fitted Thumbs Up 130's have feeling's as well you know Smile
Post #439594 22nd Jul 2015 1:25pm
Beaut of a building... looks quite a project!
Post #439609 22nd Jul 2015 2:30pm
smb
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
Can you not leave the beams exposed? Would look excellent. Thumbs Up
Post #439614 22nd Jul 2015 2:48pm
AndrewS
Unfortunately no, the external timber frame surface is in a poor condition to the point that it would be impossible to make it waterproof. The only way to fix it would be to replace with new, however the internal surface of the timber has medieval paintings on it so replacing the timber is not an option.
We are repairing where necessary, insulate between the timber and re render with a lime render system. This way we get an insulated, sound proof and breathable coating on the wall Thumbs Up
Oh and the fact that its Grade 2 listed and the conservation officer requested that the timber frame is re-covered. 130's have feeling's as well you know Smile
Post #439620 22nd Jul 2015 3:27pm
familymad
Multi skilled mental bloke. House renovation and one of the most comprehensive re-build threads.
I salute you! 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #440288 25th Jul 2015 8:48am
Bigwes2187
United Kingdom 1989 Defender 130 2.5 TD HCPU Alpine White
How much would u charge for building canopy pal
Post #458516 27th Sep 2015 8:43pm
Pickles
I salute you!
So do I!
Pickles.
Post #458563 27th Sep 2015 11:13pm
