Home > 130 > It's started, Longshanks will no longer be a Pick up
Page 8 of 13 <123 ... 789 ... 111213>
Looking good. Thumbs Up
Post #381807 25th Dec 2014 12:31pm
chadjizz
England 2013 Defender 130 Puma 2.2 HCPU Orkney Grey
that will be a tidy install. nice one.
Post #381938 26th Dec 2014 10:08am
AndrewS
Running the wiring to and from the dash to various items ie sub, amp, aux lights, heater, rear camera etc etc. I want everything nice and neat and don't want cables running under the carpets. The only way forward is out through the bulkhead and on to the various components.
I have removed the passenger speaker and managed to drill two 35mm Ø holes through the bulkhead. This was carried using a drill with a home made extension bar 300mm long in the chuck with a cone bit in the end of the bar.
Here is a pic from the inside, you will see that I have already placed the first set of cables in the conduit.
This pic is from under the bonnet the holes are located between the heater and the inner wing.
Then Mr Bell goes and send me this big ally thing Rolling Eyes
Busy on this weekend
Post #386945 10th Jan 2015 9:58am
DiscoStu
United Kingdom 2013 Defender 110 Puma 2.2 SW Santorini Black
Looking good Thumbs Up
Bulkhead holes a good idea - I eed to get a lot of wiring through there, will look at your idea My Disco 'best bits'
Defender 110 XS CSW 2013
Post #386952 10th Jan 2015 10:31am
K9F
Just a pointer....
If you are making extra holes in your vehicle to run cables through these are in my opinion the best Marine Grade cable glands you can use. Any good chandlery should be able to source them for you. Especially ideal if the cable exit/entry is visible too. Not cheap but what value do you place on quality?
Thumbs Up
http://www.indexmarine.co.uk/cable-glands.html If you go through life with your head in the sand....all people will see is an ar5e!!
Post #386955 10th Jan 2015 10:39am
AndrewS
Tidy Thumbs Up Bow down Bow down
Post #386964 10th Jan 2015 10:59am
DiscoStu
I tend to use industrial ones that are used in 300 Bar washes - they seem to do the trick Whistle My Disco 'best bits'
Post #386965 10th Jan 2015 11:02am
K9F
Normal cheap skintop plastic ones also do the job too but are not low profile. Depends on the application and what 'type' of finish you want to achieve I suppose. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #386968 10th Jan 2015 11:05am
MrFlips
Wales 2008 Defender 90 Puma 2.4 PU Santorini Black
He did the same with me, what a @£$%&*%!
I love watching this build! Peter
2008 SWB Truck Cab
1952 80" Soft top
Post #387209 10th Jan 2015 9:22pm
AndrewS
Cracking on with the wiring for the extra bits and pieces Shocked
Post #387677 12th Jan 2015 12:34pm
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
Oh lord, is this the result of someone stealing your head unit?!!!! Laughing
Post #387700 12th Jan 2015 1:13pm
AndrewS
Oh my...... got more things to fit, will it ever end Big Cry Big Cry Big Cry Razz
Post #388175 13th Jan 2015 8:37pm
DiscoStu
Go on then, I'll help you out and take them off your hands Rolling Eyes Thumbs Up My Disco 'best bits'
Post #388176 13th Jan 2015 8:40pm
AndrewS
You need a 130 for these Stu they are 'Man Brakes'
Post #388187 13th Jan 2015 8:57pm
DiscoStu
Man brakes? Try an XJR, they're man brakes! Not adverse to a 130 though, so happy to take that off your hands too Whistle Once you've finished the wiring though, bit messy at the mo... My Disco 'best bits'
Post #388190 13th Jan 2015 9:01pm
