![]() | Home > In Car Electronics > Cb radio mount |
macaiwar Member Since: 02 Aug 2014 Location: kuala lumpur Posts: 5 ![]() ![]() ![]() |
[quote="110 John"]http://www.mudstuff.co.uk/mud-defender-roof-console.html
I have my antennas on my Patriot roof rack the coax I have fed through the rear passenger doors the door seals cater ok like this and then the coax i fed inside the roof lining and out through the existing coutosy light hole as the console has a seperate hole for the light, the power leads direct from the battery and up the B pillar again in the roof lining and out the light hole all are inside the din slot radio in and hook up I have a Atas 120a on the drivers side and a Sirio 2070R on the passanger side Oops, ![]() ![]() ![]() |
110 John Member Since: 11 Jan 2014 Location: Northumberland Posts: 158 ![]() ![]() ![]() |
Hi no I havent but I should as the 857d pulls 22 amp at 100w it dont take a rocket scientist to work that one out that a 90 amp battery wont last long so yes another battery would be better
I bought a gutter mount that lasted about 3 months and cracked in half, so using a few spares and some ali angle I made this, worked a treat and was removed when i sold the truck..
![]() Click image to enlarge i also fitted a quick release mount |
yep that's what i thought too. but have you had trouble in the past with your current setup? it appears you don't seem to have any trouble at all. ![]() |
No never had any trouble the atas is earthed via the roof rack ladder which is fastened to the chassis so gives a good ground to the atas and works fantastic
dnorrishill Member Since: 15 Jul 2011 Location: Hampshire Posts: 617 ![]() ![]() ![]() |
As the bonnets are now steel (I think, certainly weighs a tonne), has anyone tried a mag mounted ariel on the bonnet?
