![]() | Home > In Car Electronics > Cb radio mount |
keen to know as well, getting a CB installed next week --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Josh K Member Since: 01 Nov 2013 Location: Herefordshire Posts: 266 ![]() ![]() ![]() |
http://www.mudstuff.co.uk/products/interio...mount.html
I used the MUD dash mount. Currently out of stock but looks really neat and tidy, almost a factory like finish. 2007 (57) Defender 90 (Sold) Looking for another to replace it. The road less travelled.... is a muddy one! |
Millsy94 Member Since: 06 Jun 2013 Location: Gloucestershire Posts: 91 ![]() ![]() ![]() |
Looks good but I have a td5 so sadly very little use
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2774 ![]() ![]() |
I got a handheld one, but when I was thinking of having a normal one I was going to mount it on a normal hang down bracket inside the cubby, thought it would have been quite neat
FCX and mobile solutions amongst others do cubbys specifically designed to take a din unit/radio too Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1826 ![]() ![]() ![]() |
In my TD5 I have installed the CB in a cubby box.
There are many ways to do this, but mine is a Exmoor cubby box and I fastened the CB to the inside of the sloping front face. I have put a gas strut on the cubby box lid to keep it open when in use. cheers simon |
Hmm I've looked at that option, trying to avoid though as I need my middle seat.
Thanks David
![]() Take a look at the range of cubbys on our website www.fcx.co.uk |
110 John Member Since: 11 Jan 2014 Location: Northumberland Posts: 158 ![]() ![]() ![]() |
I have the MUD roof console got my Yaesu FT857D in the din mount central and great
trooper Member Since: 11 Mar 2014 Location: west sussex Posts: 102 ![]() ![]() ![]() |
I also have a MUD roof console and the CB fits nicely in this, with the mike easy to use, without removing it from its clip
macaiwar Member Since: 02 Aug 2014 Location: kuala lumpur Posts: 5 ![]() ![]() ![]() |
![]() ![]() ![]() i am considering exactly the same set-up. could you share more details please? e.g. schematics & specification on set up for power (additional/standard?), antenna, etc. Thanks a million. ![]() |
http://www.mudstuff.co.uk/mud-defender-roof-console.html
I have my antennas on my Patriot roof rack the coax I have fed through the rear passenger doors the door seals cater ok like this and then the coax i fed inside the roof lining and out through the existing coutosy light hole as the console has a seperate hole for the light, the power leads direct from the battery and up the B pillar again in the roof lining and out the light hole all are inside the din slot radio in and hook up I have a Atas 120a on the drivers side and a Sirio 2070R on the passanger side [URL=] ![]() Click image to enlarge[/URL] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() Last edited by 110 John on 2nd Aug 2014 10:24am. Edited 5 times in total |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1983 ![]() ![]() ![]() |
I have the FCX twin cubby it's awesome fair play, well made and can also lock away the CB or radio
![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
![]() ![]() Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
PCA42 Member Since: 15 Jun 2014 Location: Church Stretton Posts: 468 ![]() ![]() ![]() |
My Td5 90 had a canvas on, so I mounted my CB under the dashboard just in front of the handbrake lever. That was also handy for wiring it into the fusebox (wasn't permanently hard wired into the vehicle loom). I mounted the aerial on the passenger side front wing kinda military style. Pete
2010 Discovery 4 GS TDV6 1972 Series III 88" 2.25P |
