Home > Maintenance & Modifications > Seat risers/adjusters |
Does the job on mine to alter the rake of the seat. I lifted my seat up off the seat box with my home made riser rails to enable me to slide the seat further back which then gave me the chance to move sideways as well.
27th Mar 2014 2:16pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5741 |
Packing with washers allows some extra rear travel, and height, but nothing like the rear travel you get from fitting the rails. They move all the fixings at least 2" further back, so if you want max legroom washers won't be enough.
Andy |
27th Mar 2014 2:19pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8096 |
am considering all options currently, home brew and other, thank you all for the info so far. Cheers
27th Mar 2014 8:26pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2250 |
James, I have mud rails in the 90. They are tapered and lift the rear higher than the front. Much better vision now and I can see both wing front corners comfortably seated without having to lean forward.
HTH Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
27th Mar 2014 8:35pm |
cheers Mo, didn't know they were tapered, thank you Cheers
27th Mar 2014 8:36pm |
Perhaps because they can and have run out of things to spend their money on. The Exmoor Trim ones whilst being expensive have three different locating options for the seat, are slightly higher and longer than the Mud ones and as a result there is quite a significant more adjustment to be had out of the seats. Click image to enlarge Click image to enlarge Also unless you're a real fat bloater the seats will not get cut by the side panels as someone stated. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
24th Apr 2014 1:34pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20482 |
Have you breached the 17k mark then now Mal?
I do agree though, folks that can afford it should have it if they see fit, I have no axe to grind. Only thing is the more you have to wait for stuff or save for it, it means more to you then. On topic, I do like those Exmoor risers, look good too. Is there much to be gained by them with a 90 HT with bulkhead? I wouldn't want extra height but a bit more legroom would be nice though. |
24th Apr 2014 2:20pm |
Hi Steve,
Not quite busted through the barrier yet, but will do undoubtedly. It really depends how close the bulkhead is to the rear of the seats. With mine I have the bar in lieu of the bulkhead. When I get a chance I'll take a photo with the seat fully rearwards but they are mounted in the middle position on the risers. I think the seat rake/tilt would be the limiting factor with the bulkhead. Namely the further the seat went rearwards the straighter it would have to be, I like mine tilted quite a lot as I am a bit of a straight arm driver. As an afterthought with regards to washers and 'home brewing' you could not possibly achieve the distance rearwards of the seatrails with washers alone as the rear securing point now sits beyond the raised seam behind the seats. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
24th Apr 2014 3:49pm |
ozzy57 Member Since: 14 Feb 2014 Location: Farnborough Posts: 221 |
Click image to enlarge Home brew solution. Spacer blocks machined from mild steel hex bar, threaded one end, drilled and tapped on the other. You can then have any length you want, 40mm in my case and I can now see the front near side of the car. It wasn't me! |
4th May 2014 2:15pm |
