Home > Maintenance & Modifications > Seat risers/adjusters
Page 2 of 2 <12
Grouse
+1 I don't honestly know why people buy these expensive seat risers. Range Rover Classics used to be fitted as std with circa 1" thick heavy steel spacer washers to raise the seats 1" - they do exactly the same job. Even a few thick washers or nuts with longer bolts would do the job
Post #319508 27th Mar 2014 1:56pm
JWL
Does the job on mine to alter the rake of the seat. I lifted my seat up off the seat box with my home made riser rails to enable me to slide the seat further back which then gave me the chance to move sideways as well.
Post #319510 27th Mar 2014 2:16pm
landy andy
Packing with washers allows some extra rear travel, and height, but nothing like the rear travel you get from fitting the rails. They move all the fixings at least 2" further back, so if you want max legroom washers won't be enough.
Andy
Post #319511 27th Mar 2014 2:19pm
jst
am considering all options currently, home brew and other, thank you all for the info so far. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #319578 27th Mar 2014 8:26pm
Mo Murphy
James, I have mud rails in the 90. They are tapered and lift the rear higher than the front. Much better vision now and I can see both wing front corners comfortably seated without having to lean forward.
HTH
50 Shades of Pennine Grey
Post #319582 27th Mar 2014 8:35pm
jst
cheers Mo, didn't know they were tapered, thank you Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #319584 27th Mar 2014 8:36pm
K9F
Perhaps because they can and have run out of things to spend their money on. Whistle
The Exmoor Trim ones whilst being expensive have three different locating options for the seat, are slightly higher and longer than the Mud ones and as a result there is quite a significant more adjustment to be had out of the seats.
Also unless you're a real fat bloater the seats will not get cut by the side panels as someone stated.
Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #325821 24th Apr 2014 1:34pm
Have you breached the 17k mark then now Mal? Razz
I do agree though, folks that can afford it should have it if they see fit, I have no axe to grind.
Only thing is the more you have to wait for stuff or save for it, it means more to you then.
On topic, I do like those Exmoor risers, look good too.
Is there much to be gained by them with a 90 HT with bulkhead?
I wouldn't want extra height but a bit more legroom would be nice though.
Post #325823 24th Apr 2014 2:20pm
K9F
Hi Steve,
Not quite busted through the barrier yet, but will do undoubtedly. It really depends how close the bulkhead is to the rear of the seats. With mine I have the bar in lieu of the bulkhead. When I get a chance I'll take a photo with the seat fully rearwards but they are mounted in the middle position on the risers. I think the seat rake/tilt would be the limiting factor with the bulkhead. Namely the further the seat went rearwards the straighter it would have to be, I like mine tilted quite a lot as I am a bit of a straight arm driver.
As an afterthought with regards to washers and 'home brewing' you could not possibly achieve the distance rearwards of the seatrails with washers alone as the rear securing point now sits beyond the raised seam behind the seats. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #325839 24th Apr 2014 3:49pm
ozzy57
2002 Defender 110 Td5 CSW Alveston Red
Home brew solution. Spacer blocks machined from mild steel hex bar, threaded one end, drilled and tapped on the other. You can then have any length you want, 40mm in my case and I can now see the front near side of the car. It wasn't me!
Post #328282 4th May 2014 2:15pm
Page 2 of 2 <12
