![]() | Home > Td5 > New door hinges needed? |
Gareth Member Since: 12 Dec 2011 Location: Woodford Posts: 1116 ![]() ![]() |
All of the door hinges, including the rear door are starting to ooze rusty gunk out which looks awful. I oil them regularly, but it seems that once the internal pin has started to rust, its a constant battle. The cast bits seem ok, and someone has previously fitted stainless bolts.
Can the hinge pin be replaced with something that won't rust, or do I need new hinges complete? 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy |
Search reveals:-
http://www.defender2.net/forum/topic20529....hinge+pins http://www.defender2.net/forum/topic20529....hinge+pins If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Ok cheers. Looks like new hinges complete then. I might try and butcher one to see if it is possible to extract the pin, but as the thread says, probably easier to replace and repaint. 2021 Defender 110 X-Dynamic HSE D300 MHEV
