Home > Td5 > New door hinges needed?
Gareth
All of the door hinges, including the rear door are starting to ooze rusty gunk out which looks awful. I oil them regularly, but it seems that once the internal pin has started to rust, its a constant battle. The cast bits seem ok, and someone has previously fitted stainless bolts.
Can the hinge pin be replaced with something that won't rust, or do I need new hinges complete? 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #317868 21st Mar 2014 6:19pm
K9F
Search reveals:-
http://www.defender2.net/forum/topic20529....hinge+pins
http://www.defender2.net/forum/topic20529....hinge+pins If you go through life with your head in the sand....all people will see is an ar5e!!
Post #317888 21st Mar 2014 6:51pm
Gareth
Ok cheers. Looks like new hinges complete then. I might try and butcher one to see if it is possible to extract the pin, but as the thread says, probably easier to replace and repaint. 2021 Defender 110 X-Dynamic HSE D300 MHEV
Post #318044 22nd Mar 2014 9:33am
