Home > Puma (Tdci) > Reversing light fuse blowing
davidhenry
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
I have an irritating problem with my 2008 110 SW which I hope some advice will help to sort.
The reversing light has taken to blowing fuses but intermittently.......seems to work for several days then pops. Makes upsetting the driver behind easy when I want to park!
I'm no sparky but I've had the light off and can't see anything obviously wrong with the wires or connection that I can get to.
Any hints as to where to look for possible causes would be appreciated.
David Henry Sad
Post #315633 13th Mar 2014 11:26am
K9F
As a starting point take the bulb out and see if the fuse blows then. It'll give you an indication if it lies with the lampholder or the switch. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #315686 13th Mar 2014 6:08pm
grafty99
Before I swapped to a full led setup I kept blowing sidelight fuses, turned out to be corrosion on the positive contact in the lamp holder. Worth a look Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #315694 13th Mar 2014 6:28pm
JWL
I decided to double up my reversing lights last weekend along with the fogs and now they won't work. The fogs are fine but the reversing lights haven't got any power, the fuses are fine and there's power to the fuses. According to the Haynes book of lies on my Td5 fuse 14 is linked to the reverse lights but that also is responsible for the glowplug circuit which allthough lights up the telltale, isn't working. So a bit more investigating to be done, the switch on the back of the gearbox and the glowplug kit. Why oh why did I make that under cubby box and fix everything down, for years the cubby box has just been loose in that central spot and I've never had a reason to get under there, fix it down and hey presto a couple of months later it all has to come out Rolling Eyes
Post #315794 13th Mar 2014 11:54pm
Do you have tow electrics?
Is there a build up of crud & water in the socket or connector behind the plastic flap?
Post #315862 14th Mar 2014 10:33am
JWL
I know what you're saying bpman but I for one have a 12N plug so no reverse wire present. With mine everything points to the switch on the back of the gearbox.
Post #315879 14th Mar 2014 11:36am
A fuse blowing is a sign of a short in the positive if you ask me. WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #315886 14th Mar 2014 12:10pm
K9F
Rolling with laughter No Sh** Sherlock!!!! Rolling with laughter
Simple terms the fuse rating has been exceeded. Doesn't necessarily mean a short, just a heavier load than rated. You are probably correct in this case! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #315889 14th Mar 2014 12:23pm
JWL
Mine points to switch as the fuse hasn't blown Whistle
Post #315903 14th Mar 2014 1:17pm
Mal - Whistle Some people do have to be reminded, but your correct on what you've mentioned too. Rolling with laughter WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #315934 14th Mar 2014 3:53pm
davidhenry
Well thanks for the tips folks........went out and had a poke about............light fitting and connections look just fine...........tried without the lamp in.........put it in an out of reverse a few times just with the ignition on.........fuse fine.....replaced bulb and did the same...all ok too.............left it in reverse gear and started engine...POP! went the fuse..........as said before electrics are a mystery to me........does this point to the switch being the problem?......or any other ideas?.....any advice welcome.
Post #315959 14th Mar 2014 5:39pm
Try an LED light fixture (in the holder) or a new LED light.
Mine works with an LED fixture ( which is rubbish) but same system as you for a regular bulb. Been like that a long time.
I will go for an RDX light sometime though.
Seems to me the extra current draw required by a filament bulb causes it, although I didn't get blown fuses it just simply stopped. Rolling Eyes
Put the LED fixture in and it worked all the time... Shocked Rolling Eyes WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #315962 14th Mar 2014 5:54pm
K9F
Lampholder.....If the fuse doesn't rupture with ignition on and bulb out with reverse selected everything is fine as far as the lampholder. Fitting an LED in lieu of a normal filament just disguises the root cause it does not sort it! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #315979 14th Mar 2014 6:20pm
What do you think it is then Mal? Poor contact on the holder or possibly similar on the switch side? Always is power there on mine just it doesn't seem to like the filament type bulb.
Is it perhaps done thing to do with the extra resistance of a filament bulb compared to an LED?
I even got the dealer to sort this out a few years ago, and they did it worked for a few days and stopped yet again with a filament bulb.
Seems to be a common issue with the early Pumas that the revers light like to play funny Censored .. WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #315985 14th Mar 2014 6:44pm
K9F
Ignition on and reverse selected if you have access to a multimeter check you have a full 12 volt supply at the centre contact of the filament. Then with no power and the ignition off and out of reverse check for resistance between the centre positive contact and earth (there should be open circuit indicated) and negative contact to earth (there should be 0 ohms). Better still do the same check from the positive to earth using an insulation tester and the results would indicate if you have an insulation breakdown between the switch and the holder. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #315990 14th Mar 2014 7:10pm
