Home > Puma (Tdci) > Reversing light fuse blowing
Page 2 of 2 <12
Shall have to try that. As ever thanks Mal really helpful. Thumbs Up To be honest though I have only ever played about with it not truly went yo fix it. $W33T $0U7H3RN $UG4R
Post #316006 14th Mar 2014 6:38pm
martinfiattech
If i understand correctly, reverse selected. yes
Ignition on bulb lit yes ?
then crank engine in reverse fuse blew yes ?
Place in reverse inspect wiring to and from switch poss chaffed wire on gearbox, or wiggle lighting loom may induce fault.
Place test bulb in place of fuse, bulb lights you`ve found your short, or you may have a faulty switch.
electrics easy, innit
Post #316191 15th Mar 2014 3:28pm
davidhenry
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
K9F wrote:
Ignition on and reverse selected if you have access to a multimeter check you have a full 12 volt supply at the centre contact of the filament. Then with no power and the ignition off and out of reverse check for resistance between the centre positive contact and earth (there should be open circuit indicated) and negative contact to earth (there should be 0 ohms). Better still do the same check from the positive to earth using an insulation tester and the results would indicate if you have an insulation breakdown between the switch and the holder.
Bought a nice new Gunson multimeter....just need the 2 week course to learn how to operate it!.
Shows 12.45 Volts for your first check...think i've done the next two bits and all seems ok.........as this is intermittent I am heading for the reverse switch on the gearbox as suggested by martinfiattech..........curious about getting to it as from initial rooting about underneath it seems well hidden!.......cubby box out and floor up the way forward?
Further to the above........rooted about and wiggled every wire I could find...replaced fuse and light on.......stood at rear admiring the bright glow and decided I'd had enough of electrics for today......shut the rear door.....light went out!....checked fuse......blown!.........any more suggestions folks?....not got a lot of hair to start with and all this head-scratching is not doing me any favours! Crying or Very sad
Post #316200 15th Mar 2014 4:05pm
JWL
Sorted mine(add smug smiley). Mats out, transmission tunnel out along with the associated faffing with the fuse board, cubby out, undercubby box out, plate off and found both wires had broken just between the plug and the switch. Joined and soldered back together and sorted. Checked gearbox level while I could get at the plug, fiddled with the handbrake then the hour and a half putting the effin thing back together Rolling Eyes
Post #316213 15th Mar 2014 5:27pm
martinfiattech
hiya as your light went out when you shut your rear door its looking like the switch should be ok.
did you place a test bulb in place of the fuse.
As when your short appears the bulb will light and pull all current within the circuit to ground, if you rig it up on a nice length of wire. you have a nice bit of kit that's inexpensive and dead handy.
I.E for arguments sake say , bulb positive pole to fuse holder top pin and bulb negative pole to fuse lower lower pin, remove fuse (the bulb will act as fuse so if it all goes wrong bulb blows and cuts power, just make sure none of the wires touch each other across the fuse holder) of course you need a 21 watt bulb.
Then wiggle everything / slam doors when bulb lights you`ve got it.
I`ve made one of these with a bulb and a buzzer its done me a great service for god knows how many years.
Used it on Wednesday for exactly the same fault on a motorhome, blokie spent 200 quid on air flow meters (reverse lights on a ducato fead by air flow meter circuit, and all it was, was a short on his secondary electrics on his tow bar on his caravan,
Which is good for me we don`t do caravans Very Happy but it did look daft a motorhome and a caravan together, would you call that a terrace or a semi ?
Post #316224 15th Mar 2014 5:52pm
Useful thread for further info: http://www.defender2.net/forum/topic3724-30.html $W33T $0U7H3RN $UG4R
Post #316230 15th Mar 2014 6:38pm
Page 2 of 2 <12
