Home > Maintenance & Modifications > Puma Gearstick rattle / vibration cure guide (with photos)
Page 6 of 6 <123456
nitram17
Post #928622 5th Nov 2021 12:44pm
Magoyo
Argentina 2009 Defender 110 Puma 2.4 HT Corris Grey
What an excellent post, months suffering from that noise, and the solution so close and simple. I am these days in charge of eliminating many small but unbearable noises. thank you ¡ Thumbs Up
Post #942642 15th Feb 2022 9:38pm
Thumbs Up TheThunderRolls🇬🇧🇺🇸
Post #942643 15th Feb 2022 9:46pm
Magoyo
I did my job today, as you said, it was very easy to disassemble, but I found the weights very firm, without loose movements... I found some white grease, it is possible that more grease is needed, do you have any idea what kind of grease should be added? Thank you very much. and it is true, I had a little more work to place the cover but nothing impossible.
Post #943169 20th Feb 2022 4:41pm
Cragster69
Scotland 2007 Defender 110 Puma 2.4 CSW Cairns Blue
I did this repair over the weekend and have cured the rattle in 5th and 6th while on the Motorway, not tested it in low range yet. My son thought we had broken the gearbox due to the racket coming from the weights in low range.
I tried refitting the rubber gaiter with bicycle tyre levers but couldn't.
I would recommend the carpet removal and pulling the rubber gaiter and then carpet over the gear lever before refitting this only needed 10 minutes in total as opposed to the 30 minutes wasted trying to pull the gaiter back up, not to mention the skin I've lost from my fingers. Big Cry
Post #949239 13th Apr 2022 9:22am
You can do it that way too yes, only some people with matting or carpet with sill protectors etc might find it even more work to take the matting out.
But yes. The ideal time to do it is with matting or carpet out.
That also includes being the ideal time to fit a Shift R or Slickshift and grease up plus spacers fitting if anyone wanted to go that route. TheThunderRolls🇬🇧🇺🇸
Post #949283 13th Apr 2022 6:06pm
Joe22
 2004 Defender 110 Td5 CSW Tonga Green
Can anyone advise if this would be the same ‘procedure’ in a 2004 110 td5?
Rattling in 5th / on the motorway is driving me insane Big Cry
Post #1030895 7th Apr 2024 9:10pm
The TD5 has an entirely different gear lever, so unfortunately this procedure won't help you.
Post #1030906 7th Apr 2024 10:52pm
Perhaps some fixings are loose on the TD5? TheThunderRolls🇬🇧🇺🇸
Post #1031018 8th Apr 2024 10:58pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
Just joined the Rattling Gearstick Society and thanks to this thread fixed it in five minutes + the time to let the superglue cure Thumbs Up With greasy fingers I managed to pull up the gaitor.
I was also able to calm a friend down who told me yesterday there was something wrong with his gearbox - a rattle that goes away when he touches the gearstick.
Post #1037703 17th Jun 2024 6:45pm
Post #1037803 18th Jun 2024 6:03pm
Page 6 of 6 <123456
