Home > Tdi > Clonk when changing gear.
Tia4
United Kingdom 1998 Defender 90 300 Tdi SW Cairns Blue
My 300tdi that has covered round about 108000 miles has started to make a noise when I depress the clutch pedal and change gear and again when I release the pedal this occurs in all gears not sure where to start looking or how also a bit concerned if it could cause more problems if I drive it to far now I have noticed it.
I also have a problem with my speedo I am sure it reads to high and also at lower speeds it jumps around a lot and does not settle back to zero always rest just below the 10 mph mark (I know it's not to much of a problem does make me think I have got a very fast defender though)
Post #312296 28th Feb 2014 11:41am
Laurie
Check your propshaft flange bolts.
Check your A frame ball joint.
Post #312300 28th Feb 2014 11:56am
Diablo
1984 Defender 90 200 Tdi SW Keswick Green
Also check bushes and the state of your diffs.
Post #313463 4th Mar 2014 5:46pm
Martin
Site Admin
I had a horrid clunk which I had down as a failing prop or diff. Turned out to be the A-arm ball joint.
If doing it yourself I can thoroughly recommend the OEM quality complete fulcrum and ball joint assembly, rather than farting about trying to extract the corroded-in ball joint.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #313472 4th Mar 2014 6:05pm
StephenO
I have a bit of a clunk as well as you describe. Mines is an A frame arm bush, the bush was fitted a year ago but has started to dislodge so worth a check! Thumbs Up 2007 Defender Puma Tonga Green
2015 Range Rover Sport Autobiography Corrie Grey
1968 Series 2a Bronze Green
1995 Defender 90 Coniston Green
2005 Discovery 3 Zambezi Silver
Post #313626 4th Mar 2014 11:21pm
Tia4
Hows best to check the A frame bush
Post #313766 5th Mar 2014 5:25pm
StephenO
Lie underneath the car and get someone to rock the defender back & forth, check all your bushes as he's doing it. That's how we establish what bush if was if that makes sense? Thumbs Up 2007 Defender Puma Tonga Green
Post #313822 5th Mar 2014 9:33pm
muckybeast
Ireland 2005 Defender 110 Td5 XS CSW Indus Silver
I had the very same symptons on my td5 turned out the half shafts and flanges were badly worn all changed now and the clunk is gone
Post #316172 15th Mar 2014 2:34pm
