Home > Wheels & Tyres > Which spare wheel carrier?
Page 3 of 5 <12345>
ericvv
leeds wrote:
The Kaymar Single pivot wheel carrier is available for £1,077 from Devon 4x4
The Safari Equip single pivot is £425
The Nakatanenga Single pivot is £425
Not sure what price the new Nakatanenga one will be at this moment.
We can supply the Nakatanenga wheel carrier or any of the Safari Equip range of wheel carriers. We can get special ones made to order as well.
Brendan
My 5 pence here. I have the Kaymar installed and quality is absolute top. Disadvantage is that opening the rear door is a two stage process. When I bought and installed the Kaymar I had never heard of Nakatanenga (or this forum) yet, decision was based on guidance from the aulro forum where many have the Kaymar.
If I were to repeat this, it is clear that the Nakatanenga single pivot would by my choice. Quality is on level playing ground with the Kaymar, there is no drilling in the rear of the truck (same as the Kaymar), but the big advantage is that the rear door opening becomes just a one stage process. The price of the Nakatanenga for the delivered quality is extremely sharp in my opinion. A friend of mine here has the Nakatanenga installed on his new truck, so I see the quality first hand. I think price/quality Nakatanenga is way above all the others, even in a league of its own.
Here some may have different opinions, but for me very important is that both the Kaymar and the Nakatanenga leave the spare wheel in exactly the same position as original. So if you don't have blackened windows, you can still use your cabin rear view mirror.
In first instance, prior to buying the Kaymar, I had bought a different one from a well known UK aftermarket producer (requires drilling in the rear panel), but when I received it, I was not convinced at all, did not install it, and moved to the Kaymar.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #311764 26th Feb 2014 5:52am
domcoutts
United Kingdom 2014 Defender 110 Puma 2.2 XS DCPU Bonatti Grey
I need to fit a carrier to my new DC, but looking through this thread it appears that the only carrier suitable for a tailgate that is mounted solely to the cross member is the Sonic one? Is this correct?
The last one I had on my old DC was a royal pain to fit as the top mounting needed to be reinforced as the bodywork flexed dreadfully, so I don't want to go down this road again... I don't believe the bodywork is the place to mount anything this weighty.
Apart from being hard to find either new or used, the sonic one is a ridiculously expensive solution for merely transporting a spare wheel... I'm positive the near-identical style carriers you see mounted to almost every Toyota and 'backie' in Africa don't cost that much!!
But are there any other options?
Post #311791 26th Feb 2014 9:03am
leeds
With any of the two stage opening of wheel carriers, I.e. You have to unfasten them from the outside, my understanding is that they are illegal to fit to vehicles if the rear door is used for passengers.
Basically passengers from the rear compartment have to be able to exit without any external assistance.
Brendan
Post #311792 26th Feb 2014 9:08am
landy andy
Yes safari equip do one for drop tailgates, it uses one of the tailgate latches, the swings out to one side, so you can drop tailgate.
http://www.safari-equip.co.uk/shop/index.p...lgate.html
Or there is a pivlock which I think is what I have.
Andy
Post #311794 26th Feb 2014 9:15am
domcoutts
Thanks Andy, but those both require mounting to the bodywork... Safari Equip do make a single pivot/single mount but that is for stationwagons, similarly it would appear, is the Natakanenga. I think the Kaymar might work like the sonic one, but at over £1k it's bonkers money... I'd rather stick the spare on the back seats!
Post #311798 26th Feb 2014 9:23am
ericvv
Brendan
Brendan, you may well have a point there. Even if at its first inspection when the SVX turned 4 years old our local tech inspection did not say anything about my Kaymar (they may have just missed it).....
The good thing is that if at future tests they would ever make this remark, my Kaymar can easily be removed without leaving any marks (i.e. holes), and then replaced by a Nakatanenga.
Next tech control is when the truck turns 7 years old.
Post #311801 26th Feb 2014 9:40am
zone30
Belgium 2011 Defender 110 Puma 2.4 X-Tech LE Nara Bronze
Post #311802 26th Feb 2014 9:40am
nakatanenga
Germany
TEASER!
Sinless steel version coming soon in bare and black powdercoat.
 WANTED:
SII or SIII in max 1.5k
Post #311806 26th Feb 2014 9:47am
ericvv
Is this a new model?
Does it replace the existing model, or is it complimentary to it?
If complimentary, what are the differences between the existing version and the new?
Tks, Eric You never actually own a Defender. You merely look after it for the next generation.
Post #311809 26th Feb 2014 9:57am
zone30
My nas step doesn't come that far to the corner... Sad
Post #311811 26th Feb 2014 10:04am
leeds
The Safari Equip rear tailgate wheel carrier from about £175
To the best of my knowledge the Extreme 4x4 ones are made by Safari Equip who are located 2 miles away from us.
The new Nakatanenga wheel carrier is a 100% stainless steel one except for the actual wheel studs. The wheel studs are a fine pitch stud so stainless steel in this application is not the best material for this application.
Brendan
Post #311817 26th Feb 2014 10:31am
nakatanenga
Germany
It replaces the old one.
Fully stainless, exept the wheel studs
no more ball bearings but something special bushes, no grease needed.
NAS step compliable
Better adjustabilty to different Defender tolerances Wink WANTED:
Post #311818 26th Feb 2014 10:33am
ericvv
Interesting, So will it be fully compatible with existing holes and without drilling in a Puma 110 Station Wagon? (like my SVX 2.4 Tdci model year 2009)
Strength of this new SS version will be equal to the current version? Or even better?
Post #311821 26th Feb 2014 10:46am
dgardel
Italy
4 years and 90000 km with Mantec and NO, 0, ZERO problems!!!!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #311825 26th Feb 2014 11:01am
Four years and 80,000 miles with Sonic3d and NO, 0, ZERO problems!!!!! Thumbs Up
Post #311829 26th Feb 2014 11:11am
Page 3 of 5 <12345>
