![]() | Home > Wheels & Tyres > Which spare wheel carrier? |
My 5 pence here. I have the Kaymar installed and quality is absolute top. Disadvantage is that opening the rear door is a two stage process. When I bought and installed the Kaymar I had never heard of Nakatanenga (or this forum) yet, decision was based on guidance from the aulro forum where many have the Kaymar. If I were to repeat this, it is clear that the Nakatanenga single pivot would by my choice. Quality is on level playing ground with the Kaymar, there is no drilling in the rear of the truck (same as the Kaymar), but the big advantage is that the rear door opening becomes just a one stage process. The price of the Nakatanenga for the delivered quality is extremely sharp in my opinion. A friend of mine here has the Nakatanenga installed on his new truck, so I see the quality first hand. I think price/quality Nakatanenga is way above all the others, even in a league of its own. Here some may have different opinions, but for me very important is that both the Kaymar and the Nakatanenga leave the spare wheel in exactly the same position as original. So if you don't have blackened windows, you can still use your cabin rear view mirror. In first instance, prior to buying the Kaymar, I had bought a different one from a well known UK aftermarket producer (requires drilling in the rear panel), but when I received it, I was not convinced at all, did not install it, and moved to the Kaymar. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
With any of the two stage opening of wheel carriers, I.e. You have to unfasten them from the outside, my understanding is that they are illegal to fit to vehicles if the rear door is used for passengers.
Basically passengers from the rear compartment have to be able to exit without any external assistance. Brendan |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5792 ![]() ![]() |
Yes safari equip do one for drop tailgates, it uses one of the tailgate latches, the swings out to one side, so you can drop tailgate. http://www.safari-equip.co.uk/shop/index.p...lgate.html Or there is a pivlock which I think is what I have. ![]() Click image to enlarge Andy |
domcoutts Member Since: 08 Dec 2011 Location: Kent Posts: 111 ![]() ![]() ![]() |
Thanks Andy, but those both require mounting to the bodywork... Safari Equip do make a single pivot/single mount but that is for stationwagons, similarly it would appear, is the Natakanenga. I think the Kaymar might work like the sonic one, but at over £1k it's bonkers money... I'd rather stick the spare on the back seats!
Brendan, you may well have a point there. Even if at its first inspection when the SVX turned 4 years old our local tech inspection did not say anything about my Kaymar (they may have just missed it)..... The good thing is that if at future tests they would ever make this remark, my Kaymar can easily be removed without leaving any marks (i.e. holes), and then replaced by a Nakatanenga. Next tech control is when the truck turns 7 years old. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
zone30 Member Since: 07 Sep 2012 Location: Gent Posts: 669 ![]() ![]() ![]() |
What about these guys, any good?
http://www.extreme4x4.co.uk/acatalog/REAR_WHEEL_CARRIERS.html |
nakatanenga Member Since: 12 Nov 2010 Location: Neumarkt Posts: 546 ![]() ![]() |
TEASER!
Sinless steel version coming soon in bare and black powdercoat. ![]() SII or SIII in max 1.5k |
Is this a new model? Does it replace the existing model, or is it complimentary to it? If complimentary, what are the differences between the existing version and the new? Tks, Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
My nas step doesn't come that far to the corner...
The Safari Equip rear tailgate wheel carrier from about £175
![]() Click image to enlarge To the best of my knowledge the Extreme 4x4 ones are made by Safari Equip who are located 2 miles away from us. The new Nakatanenga wheel carrier is a 100% stainless steel one except for the actual wheel studs. The wheel studs are a fine pitch stud so stainless steel in this application is not the best material for this application. Brendan Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
It replaces the old one.
Fully stainless, exept the wheel studs no more ball bearings but something special bushes, no grease needed. NAS step compliable Better adjustabilty to different Defender tolerances ![]() SII or SIII in max 1.5k |
Interesting, So will it be fully compatible with existing holes and without drilling in a Puma 110 Station Wagon? (like my SVX 2.4 Tdci model year 2009)
Strength of this new SS version will be equal to the current version? Or even better? Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
4 years and 90000 km with Mantec and NO, 0, ZERO problems!!!!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
![]() IID Pro MV License |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17565 ![]() ![]() ![]() |
Four years and 80,000 miles with Sonic3d and NO, 0, ZERO problems!!!!!
