![]() | Home > In Car Electronics > interior light |
VeeTee Member Since: 06 Mar 2011 Location: Somewhere Posts: 1512 ![]() ![]() |
I have the same problem.... Also no alarm (genuine alarm has been disabled, and after market immobiliser installed, all by previous owner) - my interior lights do work on manual switch but do not respond to door switches... Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
FOOTEY Member Since: 13 Feb 2014 Location: aberdeen Posts: 22 ![]() ![]() ![]() |
Do they respond when ignition on?
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20749 ![]() ![]() |
That probably explains it then.... I have an alarm on mine, if both of yours behaves in the same way then you'll know why it works in that way. You could always wire it yourself though to behave in the way you want it to though.. WeWillWinπ¬π§πΊπΈ
β½οΈπ’οΈβοΈπ§°πͺ |
Thanks Steve the previous owner was aware of fault at least he offered the tale told by L.R.{ allegedly } farmers leaving door open etc so may be system fault but cant rule out a fiddle somewhere. |
Yes Steve YOU may be able to wire it to bahave as desired but your dealing with a novice at this level, How about you VeeTee! |
Hi lorryman there is a green box Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Rewiring is not that complicated I think, but as I have just replaced the roof lining a short time ago (and forgot to address the problem then), I am a bit hesitating to start again with that. It is not the first on my priority list right now. ![]() 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
As the 10AS is present I would plug in a diagnostic tool and check the settings page before attempting to rewire the interior light. The first thing I would check is that the interior light smart option and the welcome light are set to enabled. I would have been surprised if there was no 10AS fitted as it is needed to allow a couple of other things to work on a standard Puma, as it is not just an alarm unit.
![]() ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Thanks Lorreyman
I'm off to blag a shot on the local dealers diag tool.Will let you know ![]() |
Hi just back from Greenbank 4x4 independant L.R. specialists where Ewan employed his diag box. It seems I HAVE an alarm {disabled} but NO KEY FOB sorry I should have made that more clear. Went through a pretty thorough look but it was not playing Even though he programed a fob was unable to smart the interior light. Suggested a possible ECU fault. I can see the logic as to why the interior lights are linked to alarm. Bought with 2 non fob keys so must have come from factory that way but would assume this must be re-programable? Advised to bring back for further investigation. Very helpful guy spent a good 30 mins on it. Any help before I book it in?. Thanks to you and the others for taking an interest. ![]() Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Check the ignition barrel for the transducer coil. Whether it is fitted or not will determine the settings required to be programmed into the 10AS module
![]() No transducer coil: ![]() Click image to enlarge With transducer coil fitted: ![]() Click image to enlarge HTH Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Brian - If you don't mind me asking, the page above, what sort of diagnostics displays that info and settings? A basic tool certainly doesn't or is that some mind of software linked up to a laptop? WeWillWinπ¬π§πΊπΈ
β½οΈπ’οΈβοΈπ§°πͺ |
That was taken from the 10AS settings page from a BBS MSV2 diagnostic tool linked up to my toughbook. The MSV allows access to all the modules on a Puma and allows new settings to be written direct, which can cause major issues if you dont know what you are doing.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge HTH :thumbsup: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Looks interesting, but not to be fiddled with!
![]() I now have my own custom lighting including the interior light all in sync with the system, I'm so pleased I'd be lost without it! WeWillWinπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
