Home > Technical > 4X4
merebrowpaul
United Kingdom 2009 Defender 90 Puma 2.4 HT Java Black
4X4
Not sure if this goes here feel free to move it .
I want to know with the centre diff lock applied how many wheels should spin ? i was stuck in the snow and the right front and left rear were spinning but the defender in front pulling me out had all four spinning hows that work then cheers PJ Embarassed
Post #25160 25th Feb 2010 10:02pm
dgardel
Italy
Re: 4X4
Without TC or diffs locks two wheel spinning....
with TC no spinning
with rear diff lock 1 wheel spnning
with rear and front diff locks no spinning Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #25162 25th Feb 2010 10:06pm
K9F
Here:-
http://www.defender2.net/forum/topic2427.html?highlight=diff+lock
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #25163 25th Feb 2010 10:11pm
fekete
Paul the only way all wheels will spin is with diff lockers Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #25164 25th Feb 2010 10:14pm
jools
United Kingdom 2003 Defender 90 Td5 XS CSW Zambezi Silver
If its very snowey / slippery surely you can get all 4 spinning with TC
TC measures the speed of each wheel - and brakes the one(s) that are spinning more than the others.
So if all 4 are spinning at the same speed then the TC will not activate.
Or what you will see is all 4 spinning - but the TC activating to make sure they all spin at the same speed
With all 4 spinning you will get better traction than with 2 spinning and 2 stationary.
Jools 2003 90 XS SW
Support Devon & Cornwall 4x4 Response - www.buy.at/dc4x4
Post #25169 26th Feb 2010 12:23am
Higgers
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Firenze Red
Paul,
Sonic has rear diff lockers. Thumbs Up
Post #25181 26th Feb 2010 9:24am
merebrowpaul
Higgers wrote:
Paul,
Oh all righty then that explains what was happening thought i'd broke mine Rolling with laughter Cheers higgers see ya soon
Post #25219 26th Feb 2010 2:39pm
