![]() | Home > Technical > 4X4 |
Without TC or diffs locks two wheel spinning.... with TC no spinning with rear diff lock 1 wheel spnning with rear and front diff locks no spinning Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Here:-
http://www.defender2.net/forum/topic2427.html?highlight=diff+lock ![]() Treat every day as if it is your last....one day you will be right!! |
Paul the only way all wheels will spin is with diff lockers
jools Member Since: 23 Feb 2010 Location: Devon Posts: 47 ![]() ![]() ![]() |
If its very snowey / slippery surely you can get all 4 spinning with TC
TC measures the speed of each wheel - and brakes the one(s) that are spinning more than the others. So if all 4 are spinning at the same speed then the TC will not activate. Or what you will see is all 4 spinning - but the TC activating to make sure they all spin at the same speed With all 4 spinning you will get better traction than with 2 spinning and 2 stationary. Jools 2003 90 XS SW Support Devon & Cornwall 4x4 Response - www.buy.at/dc4x4 |
Higgers Member Since: 08 Apr 2009 Location: Cheshire Posts: 668 ![]() ![]() ![]() |
Paul,
Sonic has rear diff lockers. ![]() |
merebrowpaul Member Since: 19 Dec 2009 Location: United Kingdom Posts: 162 ![]() ![]() ![]() |
Oh all righty then that explains what was happening thought i'd broke mine ![]() |
