Home > Technical > 4X4 |
Without TC or diffs locks two wheel spinning.... with TC no spinning with rear diff lock 1 wheel spnning with rear and front diff locks no spinning Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
25th Feb 2010 10:06pm |
Here:-
http://www.defender2.net/forum/topic2427.html?highlight=diff+lock If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
25th Feb 2010 10:11pm |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
Paul the only way all wheels will spin is with diff lockers NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
25th Feb 2010 10:14pm |
jools Member Since: 23 Feb 2010 Location: Devon Posts: 47 |
If its very snowey / slippery surely you can get all 4 spinning with TC
TC measures the speed of each wheel - and brakes the one(s) that are spinning more than the others. So if all 4 are spinning at the same speed then the TC will not activate. Or what you will see is all 4 spinning - but the TC activating to make sure they all spin at the same speed With all 4 spinning you will get better traction than with 2 spinning and 2 stationary. Jools 2003 90 XS SW Support Devon & Cornwall 4x4 Response - www.buy.at/dc4x4 |
26th Feb 2010 12:23am |
Higgers Member Since: 08 Apr 2009 Location: Cheshire Posts: 668 |
Paul,
Sonic has rear diff lockers. |
26th Feb 2010 9:24am |
merebrowpaul Member Since: 19 Dec 2009 Location: United Kingdom Posts: 162 |
Oh all righty then that explains what was happening thought i'd broke mine Cheers higgers see ya soon |
26th Feb 2010 2:39pm |
