Home > In Car Electronics > Carling Mom-off-Mom DP wiring diagram..?
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
Does anyone have an internal wiring diagram for the above switch. The pin-out supplied with the switch doesn't make sense, so would like to see how it's wired inside.
I was hoping to use it to switch +ve and earth for an in-cab winch control function.
Simon
Post #306408 9th Feb 2014 12:22am
K9F
These will help they're off the Devin 4X4 site....single and double pole momentary switch pinouts contained therein....the earth is usually only used as the internal light return, not as a switched return.
http://www.devon4x4.com/index.php?option=c...;Itemid=36 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #306443 9th Feb 2014 9:20am
couplands
Thanks. I have that pin out diagram and that's what confuses me. On the DP switch it describes the pins as "Power In, Power Out and Earth" per pole.
I'll just run my multi meter across the pins and find out what it's doing. Will post back the results in case it's useful for others.
Simon
Post #306451 9th Feb 2014 9:39am
VeeTee
Netherlands
Hi Simon, does this help?
 Cheers, Vincent
MySite
Post #306457 9th Feb 2014 10:11am
couplands
Thanks Vincent, that's more like what I was expecting..!
Just off to the garage to check this out..Smile
Simon
Post #306459 9th Feb 2014 10:15am
couplands
Vincent,
Done the wiring and all is well ( with the in-cab winch control). Thanks... Thumbs Up
I've got another slight problem. I've used two Carling on/off switches - one on the dash, the other in the rear, to switch a rear work light. It's a 2-way arrangement so I can switch the light on/off from the front or rear of the car. But the lights in the switches to show they are on do not correspond to whether the work light is on or not. I'd rather not have to put a separate warning light in, but can't figure out how to use the in-switch lights to show if the work light is on or not.
Anyway, lunch break now, so will scratch my head a bit more for an answer..!
Simon
Post #306515 9th Feb 2014 2:51pm
VeeTee
Netherlands
That is a well known brain teaser, but there is a solution but it requires a relay to control one of the indicator lamps.
(the diagram says 230V but off course it can be used for 12V also). Cheers, Vincent
MySite
Post #306531 9th Feb 2014 3:43pm
couplands
The problem with my set-up is that the light is integral with the Carling switch, so have no control over it, other than the position of the switch itself. Being a 2-way arrangement, the switch can be in either position, depending on the state of the other switch.
I could just run a warning light from the work light, but that seems a bit clumsy.
cheers
simon
Post #306629 9th Feb 2014 8:00pm
VeeTee
Netherlands
Simon, I know - you'll have to modify the internal connections of the indicator in the switch. It can be done, I have seen this modification done by a fellow club member.
Don't think a plug & play solution exists... Crying or Very sad
Cheers, Cheers, Vincent
MySite
Post #306659 9th Feb 2014 8:43pm
couplands
Ah, OK...I didn't know you can take the switches apart. I have a spare one, so will have a look.
Thanks for the idea. Thumbs Up
cheers
simon
Post #306662 9th Feb 2014 8:45pm
VeeTee
Netherlands
You're welcome Wink
Succes with the modification Thumbs Up
 Cheers, Vincent
MySite
Post #306677 9th Feb 2014 9:13pm
couplands
Deleted
Post #306739 9th Feb 2014 11:56pm
couplands
Vincent,
I'm just trying to get my head around this circuit. In the top picture, wouldn't the relay coil form a closed circuit and also allow current to flow through the work light..?
cheers
simon
Post #306816 10th Feb 2014 2:30pm
mobilecentre
It depends on the type of switch as Carling offer many variations.
Some have a separate warning light as in two completely separate wires that need to be connected, others have the circuit connected internally so driven by switch position so when the output is live the warning light is illuminated.
Post #306835 10th Feb 2014 4:22pm
VeeTee
Netherlands
cheers
simon
Hmmm, you could be right there Shocked I saw this on an electronics forum, so thought that would work. May be it depends on the resistance of the coil, indicator and work lamp, but now I have my doubts too Embarassed
Guess more home work Laughing
Concerning the modified carling switches I am sure it can be done Wink Cheers, Vincent
MySite
Post #306871 10th Feb 2014 6:10pm
