![]() | Home > In Car Electronics > Carling Mom-off-Mom DP wiring diagram..? |
These will help they're off the Devin 4X4 site....single and double pole momentary switch pinouts contained therein....the earth is usually only used as the internal light return, not as a switched return.
http://www.devon4x4.com/index.php?option=c...;Itemid=36 If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1826 ![]() ![]() ![]() |
Thanks. I have that pin out diagram and that's what confuses me. On the DP switch it describes the pins as "Power In, Power Out and Earth" per pole.
I'll just run my multi meter across the pins and find out what it's doing. Will post back the results in case it's useful for others. Cheers Simon |
Hi Simon, does this help?
![]() 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
Thanks Vincent, that's more like what I was expecting..!
Just off to the garage to check this out.. ![]() Cheers Simon |
Vincent,
Done the wiring and all is well ( with the in-cab winch control). Thanks... ![]() I've got another slight problem. I've used two Carling on/off switches - one on the dash, the other in the rear, to switch a rear work light. It's a 2-way arrangement so I can switch the light on/off from the front or rear of the car. But the lights in the switches to show they are on do not correspond to whether the work light is on or not. I'd rather not have to put a separate warning light in, but can't figure out how to use the in-switch lights to show if the work light is on or not. Anyway, lunch break now, so will scratch my head a bit more for an answer..! Cheers Simon |
That is a well known brain teaser, but there is a solution but it requires a relay to control one of the indicator lamps.
![]() (the diagram says 230V but off course it can be used for 12V also). Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
The problem with my set-up is that the light is integral with the Carling switch, so have no control over it, other than the position of the switch itself. Being a 2-way arrangement, the switch can be in either position, depending on the state of the other switch.
I could just run a warning light from the work light, but that seems a bit clumsy. cheers simon |
Simon, I know - you'll have to modify the internal connections of the indicator in the switch. It can be done, I have seen this modification done by a fellow club member.
Don't think a plug & play solution exists... ![]() Cheers, Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
Ah, OK...I didn't know you can take the switches apart. I have a spare one, so will have a look.
Thanks for the idea. ![]() cheers simon |
You're welcome
![]() Succes with the modification ![]() ![]() 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
Deleted
Vincent, I'm just trying to get my head around this circuit. In the top picture, wouldn't the relay coil form a closed circuit and also allow current to flow through the work light..? cheers simon |
mobilecentre Member Since: 05 Mar 2012 Location: Evesham Posts: 645 ![]() ![]() |
It depends on the type of switch as Carling offer many variations.
Some have a separate warning light as in two completely separate wires that need to be connected, others have the circuit connected internally so driven by switch position so when the output is live the warning light is illuminated. |
Hmmm, you could be right there ![]() ![]() Guess more home work ![]() Concerning the modified carling switches I am sure it can be done ![]() 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
