Home > Puma (Tdci) > I AM going to need a CAT!
Page 3 of 3 <123
K9F
I reckon it's exactly the same as this one available for weld on £36, bolt on £45 welds or bolts straight to your existing decat pipe....Ironically the link you posted sell the Griffin Exhaust Systems and this one is from the Griffin Shop...Quite a few watchers too....
http://www.ebay.co.uk/itm/Catalytic-conver..._720wt_960
I think they look what they are a bit 'tin pot' perhaps? Whistle If you go through life with your head in the sand....all people will see is an ar5e!!
Post #321431 3rd Apr 2014 9:36pm
spudfan
Ireland
Probably not much help but....
http://www.defender2.net/forum/topic27986.html 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #321435 3rd Apr 2014 9:47pm
K9F
Spud the joke was absolute pants the first time you posted it...... Laughing
Have another quart of whiskey and go to bed! Rolling with laughter If you go through life with your head in the sand....all people will see is an ar5e!!
Post #321438 3rd Apr 2014 9:51pm
spudfan
Ireland
It wasn't a joke. It was something very technical that I managed all by myself. I didn't even have to consult the Mrs. It was a real Land Rover MAN day. Mr. Green 1982 88" 2.25 diesel
Post #321442 3rd Apr 2014 10:09pm
martinfiattech
Just remember from a testers point of view if looks like a cat it`s a pass weather it`s fake or not.
As for D,P,F, bodge make it good already pulled one on a van he was`ent happy. no dpf but all wires and pipes sitting there, silly man.
If you put a big metal box around it. It`s pass and advise as it`s a visual inspection only. We can`t remove it although we will assume it`s dodgy. so don`t get cocky as a vt 17 form and a visit to a full and proper vosa testing centre may get you a pg9 and trouble.
The rest is up to you
P.s there are plans to check ecu parameters and nitrogen levels at tail pipe ect in time, so the smoke test as we know it may change.
As with all things vosa when it comes into force who knows...........
Please no arguments, not taking sides I`am just an mot tester following the book. whose land rover is due for it`s first mot in 2 months time and yes the cats still original and fitted it`s still under warranty and to me that's more important than the mot will ever be....
Post #321794 5th Apr 2014 7:41pm
Egghead
Quite. And how tin pot does that look?!!! If I was MOTing I would be especially unimpressed with that cheap looking can welded onto a gleaming stainless steel exhaust system, especially when it looks nothing like the original!
Post #321858 6th Apr 2014 8:18am
K9F
Nearly there.....
Plus.....+++++
Equals....====
Total cost was the same amount I sold my old cat to a fellow forum member for. Nothing ventured, nothing gained but it has been a little headscratching but enjoyable with a good result I think. Just need to get the two tig welded together next week and nailed on the truck. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #324543 18th Apr 2014 5:40pm
K9F
Tig welded in situ and now ready to fit.
Post #325995 25th Apr 2014 2:17pm
K9F
Deed is done. Had a nightmare undoing one of the 15mm M10 decat pipe securing nuts. Ended up with a Dremmel and an unscheduled hour cutting the nut off. Replaced the nuts with 17mm stainless M10s which will be a little more substantial should they need to come off again. Gave my old decat to a fellow forum member to have something to work with should he decide to go down a similar avenue.
Post #326243 26th Apr 2014 4:16pm
T1G UP
so once mot'd that'll come off?
Post #326265 26th Apr 2014 5:53pm
rustyboxx
United Kingdom 2015 Defender 90 Puma 2.2 CSW Montalcino Red
I hope Mal doesn't mind me chipping in but noo, that stays on post MOT and should be a fit for life job. Having seen his handywork up close it's a fantastic job and looks every bit like a sports cat should do. Can't see why it wouldn't pass the visual inspection Thumbs Up
As ever, Mal's attention to detail and quality of workmanship is excellent. Cool 2015 90 XS CSW TDCi - Beautiful
2007 110 XS DCPU - An itch that needed scratching
2005 90 Td5 XS CSW - Utterly brilliant
2001 Discovery 2 ES Auto - A phase I went through
1996 90 Tdi CSW - Uber reliable
1989 90 2.5 Petrol Hardtop - My first proper Landy
1985 Range Rover Vogue V8 -Troublesome
Post #326276 26th Apr 2014 6:47pm
K9F
No permanent fit! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #326277 26th Apr 2014 6:48pm
Page 3 of 3 <123
