![]() | Home > Puma (Tdci) > I AM going to need a CAT! |
I reckon it's exactly the same as this one available for weld on �36, bolt on �45 welds or bolts straight to your existing decat pipe....Ironically the link you posted sell the Griffin Exhaust Systems and this one is from the Griffin Shop...Quite a few watchers too....
![]() http://www.ebay.co.uk/itm/Catalytic-conver..._720wt_960 I think they look what they are a bit 'tin pot' perhaps? ![]() Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 3rd Apr 2014 10:49pm. Edited 1 time in total |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4773 ![]() ![]() |
Probably not much help but....
http://www.defender2.net/forum/topic27986.html 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
Spud the joke was absolute pants the first time you posted it......
![]() Have another quart of whiskey and go to bed! ![]() Treat every day as if it is your last....one day you will be right!! |
It wasn't a joke. It was something very technical that I managed all by myself. I didn't even have to consult the Mrs. It was a real Land Rover MAN day.
![]() 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
Egghead Member Since: 25 Nov 2012 Location: Surrey Posts: 256 ![]() ![]() ![]() |
Quite. And how tin pot does that look?!!! If I was MOTing I would be especially unimpressed with that cheap looking can welded onto a gleaming stainless steel exhaust system, especially when it looks nothing like the original! |
Nearly there.....
![]() Click image to enlarge Plus.....+++++ ![]() Click image to enlarge Equals....==== ![]() Total cost was the same amount I sold my old cat to a fellow forum member for. Nothing ventured, nothing gained but it has been a little headscratching but enjoyable with a good result I think. Just need to get the two tig welded together next week and nailed on the truck. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Tig welded in situ and now ready to fit.
![]() Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Deed is done. Had a nightmare undoing one of the 15mm M10 decat pipe securing nuts. Ended up with a Dremmel and an unscheduled hour cutting the nut off. Replaced the nuts with 17mm stainless M10s which will be a little more substantial should they need to come off again. Gave my old decat to a fellow forum member to have something to work with should he decide to go down a similar avenue.
![]() Click image to enlarge ![]() Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
so once mot'd that'll come off?
rustyboxx Member Since: 08 Oct 2012 Location: Poole Posts: 548 ![]() ![]() ![]() |
I hope Mal doesn't mind me chipping in but noo, that stays on post MOT and should be a fit for life job. Having seen his handywork up close it's a fantastic job and looks every bit like a sports cat should do. Can't see why it wouldn't pass the visual inspection
![]() As ever, Mal's attention to detail and quality of workmanship is excellent. ![]() 2007 110 XS DCPU - An itch that needed scratching 2005 90 Td5 XS CSW - Utterly brilliant 2001 Discovery 2 ES Auto - A phase I went through 1996 90 Tdi CSW - Uber reliable 1989 90 2.5 Petrol Hardtop - My first proper Landy 1985 Range Rover Vogue V8 -Troublesome |
No permanent fit!
