![]() | Home > Td5 > Alcantara alternative |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 ![]() |
Fake suede fer the win thread closed
http://www.ebay.co.uk/itm/Super-suede-Faux...1225777654 Pov.spec,ftw. 2006, 110,TD5. |
yobbie Member Since: 15 Nov 2010 Location: Isle of Wight Posts: 713 ![]() ![]() ![]() |
I had mine done as well as the top half of the door panels for £300
rich Member Since: 08 Dec 2012 Location: automotive trim tech trim shop Posts: 264 ![]() ![]() ![]() |
Alston technosuede the supplier is transcal its £35 plus vat a linear meter and the number +44 (0)1506 440 111
bigscoth Member Since: 05 Feb 2014 Location: Derbyshire Posts: 27 ![]() ![]() |
Yobbie, that's exactly the look I'm after. Was that glued on to the headliner or did they do it some other way? It looks really smooth.
Do you find people -children and childish- leaving messages in the material now? ![]() Rich, thanks for the contact details. The guy who did the refurb on my 90 did such a good job that I think it deserves the hard top doing properly. |
Yobbie- That looks top notch!
![]() ![]() ![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
SachaR Member Since: 28 Feb 2013 Location: Udine Posts: 40 ![]() ![]() ![]() |
Word of advice, get it done professionally as the whole trick is in the way it is attached/glue. I used the fake alcantara on the door cars and they look OK for a couple of months and then the glue started to lift..... ended up redoing it in a fake leather
![]() Click image to enlarge 1995 300TDI CSW 90 1968 Mini Innocenti |
That's a really nice finish.
Funnily enough I'm watching some material very similar to that on the bay of E...I thought it would make nice door card covering. The farm run (similar to the school run but horses not kids) is grotty at this time of year and wipe clean is definitely the way forward. I'm planning to use adhesive panel dampening on the roof and then some closed cell foam to insulate to hopefully prevent 'the drip' and won't get the headlining trimmed till then I think. |
Concept Trimming Member Since: 02 Aug 2013 Location: Bideford Posts: 7 ![]() ![]() |
I use Technosuede for re-lining headlinings.
To recover the front, rear and top rear door sections of a 90 would cost £300 plus postage and VAT. Phone Phil on 01237 424046. |
I don't know how it was done I guess it was glued, these are the door tops they had a thin layer of foam put under them to make it more comfortable ![]() Click image to enlarge |
