Home > Puma (Tdci) > MAF Sensor out of range - P1103
WinBoot
Belgium
My engine light has come up and displays P1103 - MAF sensor in range but higher then expected.
Anyone knows how to fix this? Should blanking the EGR help or just make it worse?
Post #25036 24th Feb 2010 2:25pm
mrwoo
United Kingdom 2004 Defender 90 Td5 CSW Epsom Green
Re: MAF Sensor out of range - P1103
I have this code probably because my EGR is (partially) blanked. Have you fitted an aftermarket airfilter? This will increase the airflow.
Post #25043 24th Feb 2010 4:46pm
WinBoot
Belgium
Yes ive fitted an aftermarket but i dont want to remove it, any solutions?
Post #25046 24th Feb 2010 5:23pm
mrwoo
Dont worry about it, P1103 means it out of range but not in fault. The ECU will class this as extra load and supply more fuel accordingly.
Post #25054 24th Feb 2010 7:33pm
WinBoot
Belgium
But it wont go away will it?
Post #25073 24th Feb 2010 11:01pm
WinBoot
Belgium
Anyone has a solution to make it disappear without changing the filter?
Post #25197 26th Feb 2010 11:28am
