![]() | Home > Puma (Tdci) > MAF Sensor out of range - P1103 |
mrwoo Member Since: 03 Jan 2008 Location: Cheshire Posts: 286 ![]() ![]() ![]() |
I have this code probably because my EGR is (partially) blanked. Have you fitted an aftermarket airfilter? This will increase the airflow. |
WinBoot Member Since: 09 Jan 2010 Location: Ieper Posts: 28 ![]() ![]() |
Yes ive fitted an aftermarket but i dont want to remove it, any solutions?
Dont worry about it, P1103 means it out of range but not in fault. The ECU will class this as extra load and supply more fuel accordingly. |
But it wont go away will it? |
Anyone has a solution to make it disappear without changing the filter? |
